Thu, Jan 30, 7:54 AM CST
Subject: Why is this happening?
Jalexan ( ) posted Wed, 01 June 2005 at 12:30 PM ยท edited Sun, 26 January 2025 at 3:25 PM
Hi, I created a new terrain and it's size is 1024x1024, you can see it top left, but when that terrain is in the main viewer(bottom right) it is really flat. Does anybody know why it does this and/or how to fix it? Thanks Jon www.jonsmedia.com
dburdick ( ) posted Wed, 01 June 2005 at 1:56 PM
If you want to scale up the height, just select the terrain in the Front or Top views and then pull the scale handle upward.
Jalexan ( ) posted Wed, 01 June 2005 at 2:03 PM
Well, it's always the simplest things!! God, I need to go back to the tutorial. Thanks, that did it, don't know what I was thinking. Cheers Jon www.jonsmedia.com
Dragontales ( ) posted Thu, 02 June 2005 at 1:36 PM
Actually, thanks to your image, it looks like you're clipping the terrain very low. Try upping the "clip" slider all the way up, or most of the way up. This function will "cut-off" terrain elements above the clip line. Dragontales
