Wed, Feb 5, 1:08 PM CST
Subject: importing a bryce scene into Poser
vulcanccit ( ) posted Wed, 01 June 2005 at 5:38 PM ยท edited Wed, 05 February 2025 at 12:56 PM
I know you can import a jpg in as a background but can you pull the entire bryce Scene in? trees, and objects just as you had it over in Bryce? I did go the other direction and pulled my people from Poser into Bryce (actually Daz Studio) but it really messed the people up, their arms were backwards...and one leg...it was like a bad transporter accident from Star Trek. :)
JenX ( ) posted Wed, 01 June 2005 at 7:13 PM
Yikes! Did you make sure you had the most recent copy of D|S? That may have been the problem. IIRC, you can't import trees or booleans. Then again, I'm not a Bryce expert by any stretch of the imagination :( MS
Kristta ( ) posted Wed, 01 June 2005 at 7:19 PM
Unfortunately, what you want to do is not possible. If you could manage to group it together, you would still have a sky problem. The sky does not seem to be a selectable object in bryce. If you could make it all into an obj or something, then it might work. BUT you'd have texture and map problems. Your best bet is to try to re do the people portion of it directly in Daz Studio and go from there. If I'm wrong, somebody please say something because I've wanted to do the same thing but in almost two years......still haven't got any where.
wdupre ( ) posted Wed, 01 June 2005 at 7:36 PM
you are not wrong, the only things exportable from bryce are obj files which you have imported and terrains, none of the primitive objects or skys will export.
vulcanccit ( ) posted Wed, 01 June 2005 at 11:45 PM
As far as I know it is the latest version of Daz Studio, its only a month old.. I will try again... I just like the lighting better in Poser and the Rendering... at least for the people. It is SO MUCH FUN anyway you look at it!
