Attached Link: http://meshuggah.4fo.de/Beams.htm
I googled and found this recipe for Radial Blur. When turned into a set of Nodes (after a lot of tweaking values), I get whats shown above.You would need a similar setup but use a scale in UV to create the 'radial blur', on each image the UV scale is getting smaller.
We used only 8 images but the more you add the less stepped the resulting blurred image will be.
jolly
I was wonderin' if (hopin') there's any way to make a node/ combination that will give a "radial blur" type effect? TIA
WARNING!
This user has been known to swear. A LOT!
