Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 12:37 pm)
Attached Link: http://home.pb.net/~stevecox/uvmapper.htm
Try using UVMapper to generate a template that you can then paint on in Photoshop. You'll need the umbrella as a obj.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I want to use an umbrella in a poser scene and color it with blue and yellow stripes. I had one umbrella that I downloaded from somewhere called umbrella.zip (2/6/00, no author). The zip file contains a file called UmbrellaTexmap.jpg. I thought I could read this file into PhotoShop, paint the design I wanted, then load it into P4 as a texture map and have the design I wanted. However, the UmbrellaTexmap.jpg does not correspond to the prop. I found another umbrella at the Props Guild by Trimax. This is not the umbrella above, but would be adequate if I could paint on it. Alas, it does not contain a texture map at all. Can someone please help me to get this to work?
