Sat, Feb 15, 1:55 AM CST
Subject: How to create Light beam in Bryce 5???
ghaniz78601 ( ) posted Tue, 07 June 2005 at 10:37 PM · edited Tue, 04 February 2025 at 9:46 AM
How to create Light beam in Bryce 5 please Help me I want to make light beam through metal holes with animation.... there is a metal piece which has somes holes and i want to show that light is coming from it like a beam how to possible please help. Thanks
CrazyDawg ( ) posted Tue, 07 June 2005 at 11:39 PM
ghaniz, try placing a radial or spot light behind the metal that has the holes in it. then adjust the light to suit your needs.
I have opinions of my own -- strong opinions -- but I don't always agree with them.
vasquez ( ) posted Wed, 08 June 2005 at 12:43 AM
well... it's a volumetric material matter. Just do a cylinder coming out od the hole you've done (make the cylinder with bigger diameter than the hole, then go to the material lab go into volume material and select "standard volume light" add a light inside the metallic object and render. -Caution: volume materials increase your render time - hope it helps. vasq
danamo ( ) posted Wed, 08 June 2005 at 12:45 AM
Attached Link: Peter Sharpe's tutorials
If you are not familiar with it, let me recommend Peter Sharpe's site which has an excellent tutorial on streaming light rays, among many others.
Vile ( ) posted Wed, 08 June 2005 at 1:41 AM
Also a great tip if you are new do a search through the forum right here. This topic I am sure has been discussed many times and you may find exactly what you wanted. Good luck let us know how it turns out!
