Check to make sure you have raytracing enabled in Firefly, because you need it for AO to work.
There's an obvious and distinct difference in how a render looks with and without AO (when it's used properly). So you are probably either doing something wrong, or perhaps just missing a simple step somewhere.
Message edited on: 06/10/2005 17:48
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
Yeah but the lighting system is as simple aas anything. Even Truespaces is superior. I'm not refering to the quality of the lighting. I'm refering to the actual tools and how you can handle them. Posers is amatuerishily designed. Thats all I mean. Rather than taking a que of the most common ways to design a light tool set. AS found in MAX, Truespace, Lightwave and countless others. The Author desided to make up his own. And that has prven to be a very bad idea
So far I see zero difference between just useing the IBL lights and using them with Abient Occlusion. Why is it that they seem to have taken the time to rework some portions of Poser but still the lighting tool set is just as bad as all previous versions. Don't they know that thier tool set is crap compared to Truespace or MAX? Its far easier to place and manuver lights in those programs than its ever benn in Poser. Its clear the light tool set was an area where the Author had little common sense.
