Fri, Nov 22, 7:44 AM CST
Subject: Time Saving Tip ?
TheBryster ( ) posted Sun, 12 June 2005 at 4:50 AM · edited Fri, 22 November 2024 at 7:43 AM
Forum Moderator
Some of the gods probably know this already, but I thought I'd post this anyway in case you don't.
OK, so you just spent 5 days waiting for your final render to finish, but OMG! - Vicky's left eye doesn't quite match her right eye, or you forgot to make sure that little dog in the background was facing the right way.....whatever.
Here's the thing -
Save your final render.
Click to go back to your wire-frame.
Make that tiny little adjustment.
Click to go back to your render.(DO NOT HIT THE MAIN RENDER BUTTON)
Click & Drag over the part you adjusted and hit the plop-render button.
Wait for the plop-render to finish.
Now, click the little down-arrow next to the plop-render window and select 'collapse section'.
Your re-rendered part should now match the rest of your pic!
...and you just saved 5 days re-rendering your big pic!
Well it works for me!
Message edited on: 06/12/2005 04:52
sackrat ( ) posted Sun, 12 June 2005 at 12:26 PM
If Vicky's eye offend thee,........then pluck it out.
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
tjohn ( ) posted Sun, 12 June 2005 at 4:12 PM
Yep, can't live without Plop Render. I use soft shadows. :^)
marcfx ( ) posted Mon, 13 June 2005 at 6:41 AM
Great tip, thanks Chris :)
Smile, your dead a long time :)
shinyary2 ( ) posted Mon, 13 June 2005 at 1:16 PM
Just to add-- If you do accidentally hit the main render button, go to File->Open Image, and open your original render, then try again. Works like a charm.
Incarnadine ( ) posted Mon, 13 June 2005 at 5:11 PM
One of the few things I miss when playing with C4D - Plop fixes!
