Thu, Jan 23, 8:40 PM CST
Subject: Poser output to QTVR - Solved
AcePyx ( ) posted Tue, 14 June 2005 at 7:50 PM · edited Thu, 23 January 2025 at 6:49 PM
Thanks to the people who helped with my Output to QTVR problem. I did eventually output my stuff in 3DS format before importing into Caligari 6.6 with the conversion module for QTVR construction. You can see the results here: www.gkrkarate.org/pages/techniqu/Stances/stancesf.html However, for some reason, my textures are not exported from P6 in any of the 3 formats I try (LWO, OBJ or 3DS). Ideas?
xantor ( ) posted Tue, 14 June 2005 at 10:18 PM
You don`t really need the textures for your stance qtvr files, people will be looking at the stance, not the texturing on the models.
AcePyx ( ) posted Tue, 14 June 2005 at 10:47 PM
No, I realise that, but by embedding a club badge into the files, it reduces the risk of other sites stealing my work. Also, it's the little touches that make the difference. What if Dreamworks said, "You don't need to texture Shrek, people will be listening to the jokes..."! I had hoped that the export process would retain the material settings, which would have prevented the shiny model surfaces. I don't enjoy working in Caligari in the slightest and I don't want to spend one nanosecond longer than I need to working with it.
EnglishBob ( ) posted Wed, 15 June 2005 at 3:50 AM
Attached Link: http://www.fignations.com/jelisa/mtl/mtl_fixer.html
I don't know the situation with Poser 6, but 3DS export in earlier versions was problematic. OBJ wasn't much better, but there is a utility to fix the texture pathnames (see link). If Wavefront is a viable alternative to 3DS for your application, it should help.
Muscleguy ( ) posted Wed, 15 June 2005 at 8:57 AM
Have you tried the viewpoint output mode. I know you can get texturse with that.
AcePyx ( ) posted Wed, 15 June 2005 at 9:17 AM
Yeah tried Viewpoint - it sucks - clothes don't fit, lighting is awful, textures look crap, materials are all shiny, file sizes way too large. Thanks though.
xantor ( ) posted Wed, 15 June 2005 at 10:02 AM
Is there no way that you can have a background picture in the qtvr file, where you could put your logo?
Bobasaur ( ) posted Wed, 15 June 2005 at 10:04 AM
Very nice and practical use of QTVR!
xantor ( ) posted Wed, 15 June 2005 at 10:28 AM
It is a good practical use of poser, too.
Bobasaur ( ) posted Wed, 15 June 2005 at 12:15 PM
I've been thinking about this all morning and I think I'm going to make one suggestion. I'm not an expert on these stances by any means but looking at the sideways profile of your "Shiko Dachi" raises some questions.
In "A" I've depicted the stance as I see it in your illustration. From what I can tell, it looks like the center of gavity is well behind the feet, and that would be impossible to hold. I'm thinking you need to either shift the trunk forward so it's centered over the feet ("B") or lean the body forward and maybe still shift it a little so it's directly over the feet ("C").
I hope I'm not out of line in suggesting this, but I mayself am recently becoming more and more aware of the center of a figure's gravity as I pose and this stood out. If there's something about the stance (or the influence of the karateka's "ki") that I'm missing, please excuse me.
AcePyx ( ) posted Wed, 15 June 2005 at 4:23 PM
I tried using simple background pictures in my QTVR, but the file size jumped by 800%!!! So I rather abandoned that approach. As for the shiko dachi, your illustation makes sense, if the person only has one leg, but with two legs the dynamic is different. It's the right angled position of the legs that provides the stance with its stability. It essentially juxtaposes the two feet at oppositer corners of a square. Maybe I didn't pose the figure well enough to make that clear. My understanding has increased considerably since I did those models, and I noticed a few bits that I should redo. Having said that, it's not a stance designed to be held for a long time - you pull someone down with it then move off, or you sink into it, then lift someone. You don't have to have balance, so much as tension.
Bobasaur ( ) posted Wed, 15 June 2005 at 5:59 PM
;-) (Thanks for the info- I didn't know.)
