Fri, Jan 10, 4:12 AM CST
Photography F.A.Q (Last Updated: 2024 Dec 31 10:42 am)
Subject: Update on B/W conversion.
Onslow ( ) posted Wed, 15 June 2005 at 6:47 AM · edited Thu, 09 January 2025 at 10:54 PM
A recent thread was about converting an image to b/w. There are lots of different methods: Greg Gorman's method or channel mixer were discussed and there are others. The problem with channel mixer is: that PS Elements does not have it. I have discovered another method which is useful for people with PS Elements and gives as good a result in my opinion. Here it is: Open an image. Add an adjustment layer for: Hue/Saturation. Reduce saturation to -100. Now people are saying 'huh' that doesn't work because it converts to b/w giving equal weight to all colours which is not how the human eye sees. It has converted yellows with the same brightness as blues, to all the same shade of grey. But wait.... Go to the 'Layers Pallette'. Change the 'Blend Mode' of your 'Adjustment Layer' to: 'Color' There you are a 'perceptual' conversion to b/w giving different weightings to different colours so the image is more as your eyes saw the original scene. The bottom four blend options(Hue/Saturation/Color/Luminosity) on the list in PS are Perceptual blends they blend weighted for how the human eye sees ie. more sensitive to Green than Blue etc. Now do any tweaks in: levels or curves on another adjustment layer and you will have a finished image.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
solrac_gi_2nd ( ) posted Wed, 15 June 2005 at 10:09 AM
Thanks Richard
this piece of information will be very useful for those who use PS Elements :)
... I 'work' with PSP :(
your contribution is very welcome always
Carlos.
TwoPynts ( ) posted Wed, 15 June 2005 at 11:59 AM
Very interesting. Too bad I don't use Elements! ;)
Onslow ( ) posted Wed, 15 June 2005 at 12:14 PM
It helps in any version of PS - I said Elements because the channel mixer is not available with elements so it is a way of getting around that. If you use the channel mixer method on an adj layer and change the blend to color you will get a better result too, especially if you are using the presets for different types of film. Unfortunately doesn't work with PSP - sorry Carlos.
Edward Lear
cynlee ( ) posted Wed, 15 June 2005 at 12:45 PM
Attached Link: "Super Easy Good B&W Conversion in Photoshop by DHolman"
thank you Richard!!! :] i kept this tutorial on converting in PS too, course this one is using the channel mixer, you or someone else might like to compare methods
Onslow ( ) posted Wed, 15 June 2005 at 2:29 PM
An image with each method - no adjustments made to any of the images after conversion.
Edward Lear
coolj001 ( ) posted Wed, 15 June 2005 at 7:31 PM
Cool info. I have Photoshop and have made a few conversions using the channel mixer(thanks be to the recent thread), but didn't know about the adjustment layer. Thanks..I must try this now :-) I realize this post is about converting from color to b/w, but I have a somewhat relevant question. I was wondering...I can set my digital camera to take b/w pictures. Would this be the best way to get a b/w image, or would converting w/the computer result in a better, as good, or not as good image. I am guessing the camera would be faster, but probably not quite as good because the camera's processing is prob. not as accurate as Photoshop for converting color to b/w. TY -Jeff
TomDart ( ) posted Wed, 15 June 2005 at 8:56 PM
This is good. I know folks who use PSElements and the method is not difficult. Thanks. Tom.
DJB ( ) posted Thu, 16 June 2005 at 1:10 AM
I thank you for this info. Off to try it now.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
tibet2004uk ( ) posted Thu, 16 June 2005 at 9:12 AM
Rich, I've tried it but I can't find that "blend mode" option! :( Help plz!
Onslow ( ) posted Thu, 16 June 2005 at 11:46 AM
It is not my intention to say one way is better than any other - people must decide for themselves by looking at full size images on screen and in print which method they prefer. The main point is the blend mode which is an improvement over using 'normal' blend for the reasons I gave if you are using the desaturation or channel mixer method. Jeff - It is usually preferable to convert to b/w in postwork because you have got more options to control the process, plus you have a colour image too. If you shoot in b/w with your camera it takes a colour image and converts it to greyscale based purely on the lightness value of the individual pixels. But it is a big advantage if you are using a compact/prosumer camera that does have a b/w mode, because most of them display what you are about to shoot in b/w on the live lcd display. It is not easy to visualise scenes in b/w and takes some practise, the display is very valuable, but then change to a colour mode for capturing the scene. Pascale - On the layers palette - highlight the adjustment layer and just above under the word 'layers' is a drop down box where you can select the blend mode. You will see the image change as you do it. (It also apperas on the window when you first choose layer adj and defaults to 'normal')
Edward Lear
tibet2004uk ( ) posted Thu, 16 June 2005 at 1:38 PM
yea I found it Rich but I guess I just don't understand the process u're talking about here! :( Oh well!
coolj001 ( ) posted Thu, 16 June 2005 at 6:48 PM
Rich, Thanks for explaining. That makes sense, and is a good idea to use the display for b/w preview. I must try this now. I was thinking that color blind people would prob. have an advantage in b/w composition. Yesterday I experimented w/this method of b/w conversion. I added a duplicate layer w/the blend mode set to color on top of the original converted to b/w channel mixed layer. I didn't notice any difference. I just now re-read what you said here and realized I didn't follow your instructions correctly. Typical of me...lol. Honest mistake though. You say do it all(channel mixer, set blend mode to color) in just one adjustment layer. I must try again... -Jeff :-)
