Sun, Feb 9, 8:22 PM CST
Subject: Conforming cloths and NGM for V3 problems - help
3DNeo ( ) posted Sat, 18 June 2005 at 7:15 PM ยท edited Sun, 09 February 2025 at 8:13 PM
I could use some help getting my custom V3 character which has the NGM natural breast morphs used working with some conforming clothing outfits. The problem is, the outfit will conform OK to most of the figure except her chest/breasts. Most likely this is due to the NGM morphs I have, but there's no way I'm getting rid of them because that's part of my characters looks. Also, I've tried all the tapering and adjustment most of the cloths have and I can't find a solution to this problem. Has anyone else used NGM or had trouble getting conforming cloths to fig correct on their custom V3 figure? If so, I could use some help to try to figure out how to get this to work. Also, I was wondering if WW wizard by PhilC would be a quick solution. I wasn't sure it would work or not for your own CUSTOM V3 figure. Thanks.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 & Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB 800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
nickedshield ( ) posted Sat, 18 June 2005 at 7:37 PM
WW does work on custom figures. What you would do is bring in the clothing and conform it. Probably have massive poke through. Then it's just a matter of deciding which set of Inflate/Deflate Buttons to use to get rid of it. If the modified figure has extremely exaggerated mammeries the results may not be to your liking. There are 4 areas that have to be fiddled with, chest, abdomen and the collars. the other aternative is to use The Tailor to transfer the morphs to the dress. Again, results can vary. Since WW gives more bang for the buck I would go that route but hurry, the sale is ove Monday.
Tashar59 ( ) posted Sat, 18 June 2005 at 8:44 PM
You could run the clothes through the cloth room if you have P5/6.
Fazzel ( ) posted Sat, 18 June 2005 at 9:45 PM
The cloth room only works on dynamic clothing, ie props type clothing. It won't work on character, ie conforming, type clothing. The only way you could use conforming clothing in the cloth room is to just load the .obj of the clothing item and then try to run that through the cloth room. But that doesn't always works because something the separate sections of the object break apart.
Tashar59 ( ) posted Sat, 18 June 2005 at 11:59 PM
I guess I better quit using the cloth room in doing just that and I will quit trying to help. Sorry.
