Wed, Nov 20, 4:48 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Function list?
ockham ( ) posted Mon, 12 February 2001 at 11:41 AM · edited Wed, 20 November 2024 at 2:24 AM
Comment: This is great! Scripting finally makes Poser do what I originally bought it for; I'd been sort of disappointed about that up till now. (No regrets, though; pre-scripting Poser has already saved my job by livening up an "interactive text" I'm developing.) Just for info to others who haven't dug into the script stuff yet: I'm a C++ programmer by trade, and it took me 2 hours of fiddling with the provided sample scripts to make the "thing I bought it for" work properly. So, if you are familiar with programming in C++ or any modern object-oriented language, Python will be easy to pick up. Question: Info about Python itself is available, but I don't see a documented list of the specific functions "inside" Poser. (Sort of like the "SDK" in Windows terms.) Some are easy to use and understand from the sample scripts, but that still doesn't tell how to use them and what the limits are. Consider a line like figure = scene.Figure("Figure 1"). I can use it by copying, but where do I find further documentation on the class-level function Figure() ? ......ockham
My python page
My ShareCG freebies
JeffH ( ) posted Mon, 12 February 2001 at 1:10 PM
Attached Link: http://www.curiouslabs.com/products/proPack/html/proPackUserGuide.html
Download the userguide .PDF, it has everything you'll need to know. http://www.curiouslabs.com/products/proPack/python/index.html
