Fri, Dec 27, 11:21 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: Scaling question for Poser6
qtbeyb ( ) posted Mon, 20 June 2005 at 10:52 AM ยท edited Fri, 27 December 2024 at 7:03 AM
Is there a way to scale my figure so that it has the exact weight and height that I want to design?
geep ( ) posted Mon, 20 June 2005 at 11:47 AM
Uh oh, there's that word again! ;=[
cheers,
dr geep ... :o]
edited 10/5/2019
bjbrown ( ) posted Mon, 20 June 2005 at 12:14 PM
Load your figure. Select its body. Look over the parameter dials for Scale. Default is set at 100%. You may increase or decrease that scale. You can scale specific parts. You can make legs shorter by setting YScale on the thighs and shins down to 90%, for example. Make them longer by going up to a YScale up to 110%. Just changing the YScale will either make them shorter but thicker, or longer but leaner (relatively speaking). Increasing the XScale on the torso a little bit can have the visual effect of adding pounds. Decreasing the YScale does the same thing, and makes the person shorter. For anything more, you need to use morph targets (downloaded or bought), or make your own in Poser using magnets.
qtbeyb ( ) posted Mon, 20 June 2005 at 12:37 PM
Thanks so much for the information! It will help me out a lot. So, let's say I wanted the figure to be 150 lbs, there's no way I can just plot that in somewhere? Would I just have to estimate the body size?
paper-tiger ( ) posted Mon, 20 June 2005 at 1:39 PM
Considering 150 lbs looks different on every person... hehe If you have V3, she also has body morphs to change her 'weight'. Some of the 'Heavy' morphs aren't particularly realistic, but you can use some of the full body morphs with negative values or in combination to get the affect you want. The only real problem is if you do, conforming clothes are a misery to fit. Hooray for dynamic cloth. -.-
bjbrown ( ) posted Mon, 20 June 2005 at 2:49 PM
Don't be afraid to guess using your eye. But, if you really need conformation that you're creating something that matches a certain set of statistics, go to an online model registry. (I don't mean model as in 3D graphic object, I mean model as in flesh-and-bones men and women who model clothes and such.) Look up some models, look at their pictures, and check their stats.
qtbeyb ( ) posted Mon, 20 June 2005 at 3:25 PM
Hooray! Thanks so much guys! Success!
