Sun, Jan 26, 3:46 PM CST
Subject: how do you load a morph target?
GothKurlz ( ) posted Wed, 22 June 2005 at 3:37 PM ยท edited Sun, 26 January 2025 at 3:26 PM
I'm working with P6, and i've never really loaded a morph target, can anyone help me please? thanks
DCArt ( ) posted Wed, 22 June 2005 at 5:50 PM
  1. Select the body part that you want to apply the morph to. 2) Choose Object > Load Morph Target. The Load Morph Target dialog appears. 3) Click the button that has the three dots on it (...). Browse for the folder that contains the OBJ file you are going to use as a morph target. Select the file, and click Open and you return to the Load Morph Target dialog. 4) Enter a name for your morph target in the Label field. For example, let's say you are adding a morph to the head that makes elf ears. Name the morph ElfEars or something descriptive like that. 5) Choose OK. If all goes well, you should return to the Poser window, and there should be a new dial for the selected part. If you receive a message that says "Target geometry has wrong number of vertices" that means either the geometry got altered in the program that you used to create the morph, or you are applying morphs for one body part to another body part. Hope this helps.
GothKurlz ( ) posted Wed, 22 June 2005 at 6:32 PM
thanks so much :)
