Wed, Feb 19, 6:24 PM CST
Subject: Is THIS possible with Vue 5 INF?
ethan ( ) posted Wed, 22 June 2005 at 7:17 AM · edited Mon, 17 February 2025 at 6:27 AM
Hey all, I want to create a animated scene where a Logo dropped from above to the ground. Ground is a boring white plane and within seconds, Grass, Trees, rocks and hills are "transforming" into the animation. I have no idea how to realize that idea. Maybe due postproduction? Render one movie with white ground and a second with the wood? But how can I make it look like its growth in a time frame? Any ideas? Suggestions?
wabe ( ) posted Wed, 22 June 2005 at 7:29 AM
How about 2-3 Ecosystems with the vegetation slightly under the white plane. First scaled to zero in z and then scale them up as animation. And vibrate them a little so that the "growing" is not too smooth? 2-3 Ecos because then you can make the grow a little different in speed and movement. Can be more of course if neccessary. Could work.
ethan ( ) posted Wed, 22 June 2005 at 7:34 AM
Great Idea! Thank you I will try it and post finals
impish ( ) posted Wed, 22 June 2005 at 10:40 AM
Isnt there a tutorial in the manual about making a plant appear to grow? You might be able to use that for close up plants while doing scaling stuff and / or fading in transparant items in the distance by animating their transparency.
silverblade33 ( ) posted Wed, 22 June 2005 at 12:51 PM · edited Wed, 22 June 2005 at 12:57 PM
"hide from render" then have it visible to render?
is that animatable?
if so better than transparency IMHO :) dern, no it ain't :(
Message edited on: 06/22/2005 12:57
lanaloe77 ( ) posted Wed, 22 June 2005 at 6:37 PM
If I was making this scene I would make two videos: one with the barren scene and the other with the plants growing. I then would composite the two videos in After Effects. Generate the mask from the second video in vue to use in After Effects. Otherwise, I would make an animated mask in AE.
