Fri, Jan 24, 8:47 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: DYNAMIC FASHION?
Fo3 ( ) posted Fri, 24 June 2005 at 1:20 AM ยท edited Fri, 24 January 2025 at 8:38 AM
Hi,please does any one know how I can get a comprehensive Poser 5dynamic cloth tutorial? Issues include;how to attach the garment to the figure. Thanks.
What is a CRIF?
Stegy ( ) posted Fri, 24 June 2005 at 1:30 AM
Attached Link: http://www.philc.net/tutorial6.htm
I found this one to be useful to me. Philc always has top quality!
karanta ( ) posted Fri, 24 June 2005 at 2:01 AM
Attached Link: http://www.laroo2.com/tut/comp/
Runtime DNA has several very good tutorials.
My Renderosity Store
EnglishBob ( ) posted Fri, 24 June 2005 at 5:00 AM
Attached Link: http://www.poserfashion.net/tutorials.htm
...and here. Not sure what you mean by "attach it to the figure" - you attach dynamic clothing to the figure in the same way that you attach real clothing to a real figure - it's usually held up by the design of the clothing. You may need to add some vertices to the constrained group before simulating, to stop things falling off.
xantor ( ) posted Fri, 24 June 2005 at 8:41 PM
You usually attach dynamic clothing to the figure by parenting it to the hip of the figure, unless the object is a top or head item then you parent the object to whichever part makes most sense.
bjbrown ( ) posted Sat, 25 June 2005 at 2:09 PM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=632
If attaching to a figure means that you don't want certain areas to fall off a figure, you do that by editing the constrained group of the clothing. Usually the merchants who sell dynamic clothing, or put stuff out for free, have already set up a logical constrained group. I recommend reading not just one tutorial, but several. Each one usually has one or two things that none of the others do. It's better to understand how dynamic clothing works, rather than just following instructions. Jusletgo's is my favorite dynamic clothing tutorial, but I have also referred to PhilC's and Hmann's are good too (though, as far as I know, Hmann's is only available in the clothing packs he sells).
