Wed, Jan 15, 3:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Subject: Tips on Tattoos?
momodot ( ) posted Fri, 24 June 2005 at 9:24 PM · edited Tue, 14 January 2025 at 11:23 PM
I have drawn some tattoos, now how do I best get them on my texture so they look in the skin, preserving the skin "texture", rather than as decals on the skin. Also still I am looking on how I can put white or black or color grease paint effect on a texture with out loosing the texture "texture" detail beneath it. Thank you.
Acadia ( ) posted Fri, 24 June 2005 at 10:15 PM
I may be wrong, but I think you have to apply the tattoo in a graphic program to the texture file and then save it. You would want to save the .jpg as a different name though, and then get MAT Pose Edit in order to create the files you need to use. At least that's my understanding of textures. I haven't made any other than for a hand fan, but that's what I had to do. I don't know if skin textures work differently or not.
Fazzel ( ) posted Fri, 24 June 2005 at 11:49 PM
Or if you don't want to clog up your hard drive with a bunch of full body texture files use a math node in the material room to combine an ordinary body texture with what you want to use as a tattoo. One image map is the body testure, the other is the tattoo using the U and V scales in the image map to size it and the U and V position to locate it .
Fazzel ( ) posted Fri, 24 June 2005 at 11:50 PM
And here is the finished result.
revric ( ) posted Sat, 25 June 2005 at 5:41 AM
There is the "Work on any body tex" tattoo kit by weezie. It works great and you do not have a bunch of full body textures lying around on your hard drive. I have used the kit and it works great.
momodot ( ) posted Sat, 25 June 2005 at 9:10 AM
Acadia, yeah... I was wanting to paste the tatoos on in Photoshop but without loosing the pore texture of the skin. That is my problem with doing make-up and grease paint also, not loosing the pore texture of the original texture. I am using www.3d.sk reference photos. Fazzel , seeing you "multiply" node makes me think that makes a lot of sense. I never have understood those math functions... I'll look at weezie but I also want to make my own tattoos. Thanks
Kristta ( ) posted Sat, 25 June 2005 at 11:43 AM
Interesting topic. bookmark. Kristta (the tattooed, pierced up freak)
Blackhearted ( ) posted Sat, 25 June 2005 at 12:08 PM
without giving away exactly how i create my tattoos, let me say that youll need a graphics editoor such as photoshop, paintshop pro, etc. then play around with the tattoo layer opacity, blend modes, etc. it helps if you have a real tattoo to observe while you do this. keep in mind that tattoos are not on top of the skin - theyre underneath a thin layer of skin which gives them a milky opacity and a little bit of a bleed. cheers, -gabriel
Acadia ( ) posted Sat, 25 June 2005 at 1:47 PM
The textures are .jpg images, and it's possible to save .jpg images without further compression. Just open the .jpg in your graphic program, do whatever changes you want, then when you save the .jpg make sure that in the options area you reduce the compression to zero or 1 and the file won't be recompressed and will maintain it's image quality.
nruddock ( ) posted Sat, 25 June 2005 at 1:58 PM
With a little thought, it should be possible to create the effect that Blackhearted mentioned, using a Shader network.
quinlor ( ) posted Sat, 25 June 2005 at 3:25 PM
Attached Link: http://www.quinlor.de/tutorials/tattoo.html
I use the same methode as Fazzel, with some aditional tricks. You find a short tutorial at the link.
Fazzel ( ) posted Sat, 25 June 2005 at 3:33 PM
quinlor, you're probably were I got the idea from. The tut looks familiar. If you are, thanks.
momodot ( ) posted Sat, 25 June 2005 at 3:47 PM
quinlor, That tutorial really works. Thanks.
shedofjoy ( ) posted Sat, 25 June 2005 at 9:44 PM
Now i wish i had thought of that little trick... Thanx Fazzel. that's one to Bookmark.
Getting old and still making "art" without soiling myself, now that's success.
Casette ( ) posted Thu, 08 September 2005 at 3:10 AM
Bookmark
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Acadia ( ) posted Thu, 09 February 2006 at 4:21 AM
momodot ( ) posted Thu, 09 February 2006 at 12:10 PM
dougmdavis2000 ( ) posted Thu, 17 May 2012 at 2:59 PM
I am using Poser Pro 2010. Is there any way to place a large tattoo in the middle of the back without clipping due to the Torso Maps being split up the middle of the back?
hborre ( ) posted Thu, 17 May 2012 at 3:23 PM
Not in Poser.  You would need a 3rd party software capable of painting across seams.  DecalMaster @ DAZ3D is designed for this, link:
http://www.daz3d.com/shop/decalmaster
And Blacksmith3D is useful for this also, link:
http://www.blacksmith3d.com/
hornet3d ( ) posted Thu, 17 May 2012 at 3:26 PM
Online Now!
I used the layers method, outlined by Blackhearted, in PaintPhopPro to apply this tattoo (which I purchased) and I was fairly happy with the result.
SamTherapy ( ) posted Thu, 17 May 2012 at 4:43 PM
That looks very effective.  Just a couple of areas where it looks pasted on, but otherwise a great looking tattoo.
