Wed, Jan 8, 9:33 PM CST
Subject: Setting Preferences
Acadia ( ) posted Tue, 28 June 2005 at 2:35 PM ยท edited Wed, 08 January 2025 at 5:27 PM
I am having a terrible time setting up my Poser interface preferences. I move the tools etc to my preferred location, resize the Pose window, go to Edit, Preferences, and set to "launch to preferred state", click "set preferred state", and then ok. Regardless of what I seem to do, when I next open Poser, the tools etc are all back to factory location, but the pose window is the size I set it at 800 x 800. I've installed poser a number of times, and did it again yesterday, but I've never had trouble setting up my preferences before. In the right side of the preferences window, do I pick "previous state" or "factory state"?
SamTherapy ( ) posted Tue, 28 June 2005 at 2:39 PM
Select "Previous State". Also, it's a good idea to select a UI dot as soon as you have your interface set up the way you like it.
Tashar59 ( ) posted Tue, 28 June 2005 at 2:48 PM
"previous state" You may want to add a couple of different settings in your UI Dots. I do this for 3 different window settings and works great when I use an old Pz3 and it doesn't fit right. I just click on a dot and it straightens and puts everything the way I like it.
originalkitten ( ) posted Tue, 28 June 2005 at 2:49 PM
click set to preffered state.....and previous state
"I didn't lose my mind, it was mine to give away"
Acadia ( ) posted Tue, 28 June 2005 at 2:49 PM
Thank you! I did the memory dot thing this time and the set up stayed the way I set it. It was driving me nutso! LOL
Tashar59 ( ) posted Tue, 28 June 2005 at 2:50 PM
Damn slow dailup, always makes for crossposting.
originalkitten ( ) posted Tue, 28 June 2005 at 2:54 PM
lol it does....drive u nutz
Acadia ( ) posted Tue, 28 June 2005 at 2:57 PM
I found a thread the other day about tips for XP users and Poser 6. I followed the initial post's suggestions and now my system seems more speedy, and so do the boards here. I have XP and Poser 5, but I figure it's still XP so I decided to try it. Glad I did.
momodot ( ) posted Tue, 28 June 2005 at 4:28 PM
Hui, I have not found the XP thread. What was the suggestion that speeded things up? Has anyone solved hoe to get Poser 6 to default to the P6 runtime even if you forget to go back there before closing Poser?
PabloS ( ) posted Tue, 28 June 2005 at 8:21 PM
"Has anyone solved hoe to get Poser 6 to default to the P6 runtime even if you forget to go back there before closing Poser?" That would be useful (or to select one to default to)!! Perhaps a python script that one would use instead of "close" would work ... if the functions reside in python.
