Tue, Dec 24, 11:58 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Source for Hexagon Manual?
nomuse ( ) posted Sun, 03 July 2005 at 11:59 PM · edited Tue, 24 December 2024 at 11:46 AM
I can't get the documentation to show up from within Hexagon (the only "help" function that works is "go to website") and since I was foolish enough to buy online all I have is the software itself...no seperate pdf.
ShawnDriscoll ( ) posted Mon, 04 July 2005 at 12:24 AM
The PDF is in the installer and is on your drive. You need to install Acrobat Reader from http://www.adobe.com to view the manual in Hexagon without problems.
nomuse ( ) posted Mon, 04 July 2005 at 3:08 AM
Sorry. Acrobat is still up, pdfs are reading fine. Trouble is, there is no pdf for Hexagon. Used to be. I read it once! But since I purchased, there is no longer any sign of the one I was reading. Nor is there anything in the installer, the demo installer, or the patch installer. I've tried installing all three, again, in hopes they might deposit a pdf somewhere, and I've searched all my drives. If there is a manual now, it is well hidden.
mdesmarais ( ) posted Mon, 04 July 2005 at 6:44 AM
On my PC, the .pdf's are located in Program Files/Eovia/Hexagon/data/doc hope that helps markd
steama ( ) posted Mon, 04 July 2005 at 10:22 AM
Inside the Hexagon application under the menu item HELP/DOCUMENTATION. This will open the PDF manual.
nomuse ( ) posted Mon, 04 July 2005 at 12:19 PM
Nope. Searched both drives. For some reason, installer didn't put a manual down. I'll see how the demo was laid out; when I tried the demo on my underpowered laptop the "help" menu route worked fine. I'll check it's drives and see if I can discover the secret to the missing manual. Perhaps I can even copy it from there. Of course, having the installer create a folder with application and documentation side by side -- like most other software -- would be a nice thing.
nomuse ( ) posted Mon, 04 July 2005 at 12:34 PM
That's really weird. Booted up the laptop in OS9, and this is the tree I observe; Applications/Hexagon.app/Contents/MacOS/data/doc/HexagonManualUS.pdf Looking at the drive where I installed the purchased version, the tree reads; Applications/Hexagon. No folder, nothing. If I might take a wild guess, it could be the naming convention of the folder makes OS-X think it is an application, and none of the file functions work correctly around it. Bolstering that theory is that I can't drag the application to the Dock, although I can copy or alias it. Again using OS9, I can view the application proper hiding several layers down the file structure. I'm gonna try some file tools and rename the folder. Maybe this will make things work nicer.
ShawnDriscoll ( ) posted Mon, 04 July 2005 at 3:37 PM
Uninstall the demo before you install the full version. Use Eovia's standard folder path for the install. Then patch.
bluetone ( ) posted Tue, 05 July 2005 at 10:34 AM
There is a hidden file trick in Mac OSX (that I don't fully understand...) that has the files located in the applications 'package.' Go to the folder where you installed the program and control-click on the application itself. You will have a pop-up menu that has an 'open package' (or something like that) option. Choose it and you'll find the hidden files including the PDFs. Hope this helps! :D
nomuse ( ) posted Tue, 05 July 2005 at 12:23 PM
Good one, Bluetone. Yep; that was the trick. I'm glad to see I was correct about the package being normally "invisible" to OS-X. Still not sure why the manual wouldn't open from within hexagon...but I have it on the desktop and can read it now, PLUS I'm now able to add Hexagon to the Dock beside the other 3d applications.
bluetone ( ) posted Tue, 05 July 2005 at 1:43 PM
Glad I could help! How do you like Hex? I haven't taken the plunge into a NEW application yet. (Ugh!)
sparrownightmare ( ) posted Tue, 05 July 2005 at 8:46 PM
Ya see, this is one of the reasons I never buy downloadables. I like having a paper manual and real CD.. Did you try contacting eovia to see if they would sell you just a manual?
nomuse ( ) posted Tue, 05 July 2005 at 9:16 PM
Just got word from Eovia this afternoon. They also suggested the control-click method. I really need to look hard at that manual because, aside from the edge tools, I can't get anything to work for me. Love those edge tools, tho. If they didn't screw up my UVmaps I'd be using them right now.
