Sat, Nov 30, 12:20 AM CST
Subject: Transparent Gloss effect on skin help...
solofalcon459 ( ) posted Mon, 04 July 2005 at 9:16 AM ยท edited Sat, 16 November 2024 at 4:25 AM
I want to apply a glossy layer on top of a skin texture, so as to give the appearance of a layer of clear material (latex) over the texture. I have done this in the past by applying a material room catsuit (not a figure, just settings) and then applying reapplying the texture. The gloss layer would stay and you could see the skin through it. Now with P6, it doesn't work. Any ideas?
momodot ( ) posted Mon, 04 July 2005 at 10:45 AM
insomniaworks ( ) posted Mon, 04 July 2005 at 11:22 AM
I would recomend applying a figure such a as catsuit and applying the glossy clear texture to that then. You didn't say what figure you are working with.
bjbrown ( ) posted Mon, 04 July 2005 at 11:23 AM
That's what Spectacular does. The closer to white you get on Spectacular, the more shine you get on the skin. Usually one chooses along the black-gray-white spectrum for spectacular, but for your particular effect you might want to play a bit with colors (which has the effect of making a colored glare rather than white glare). The other setting to play with to get your effect is highlight size, which determines how big the glare gets. If you have any MAT files for characters with glossy lips, you might also try applying one to a character, then checking the material room to see what settings were used. That could get you close to what you want.
solofalcon459 ( ) posted Tue, 05 July 2005 at 3:30 AM
Hmm...Specular makes the texture shiny but theres not an appearance of thickness (sorta like refract but not the whole figure). Catsuits give me the fits since they usually won't conform correctly. That would work though. I'm sure there's something I'm missing... Figure is V3 in P6.
momodot ( ) posted Tue, 05 July 2005 at 10:43 AM
There is a Second Skin making utility in the Market Place but it sounds like you want a material room solution.
solofalcon459 ( ) posted Tue, 05 July 2005 at 11:00 AM
I'm open to suggestions...the method I used with P5 was material room-based but anything that would work is ok with me. In the past, I used the free lilflame zipper catsuit. It was a bump map and color reflect nodes. Somehow, after I applied it and then reapplied the character's skin texture, the bump map (or something) stayed there and looked just like a clear catsuit on top of the skin. It had enough depth to give the illusion of being a layer of latex. Apparently it was an exploit with P5 since P6 won't fall for it. :(
momodot ( ) posted Fri, 08 July 2005 at 8:42 AM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=34477&ViewImage=2#Image
http://market.renderosity.com/softgood.ez?ViewSoftgood=34477&ViewImage=2#Image This is GenoCyde V3. $10 multiple textures and some clothes. Seems like the transparent gloss effect might be the use of reflection maps as well as something with the specular light in the skin materials settings?
