Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Sep 25 2:51 am)
One question/suggestion: Did you use the Poser default camera setting of 30mm? It makes the room look a bit fish-eyed. Try setting the camera to 100mm or 110mm, which will make it look more real to the eye. Otherwise it's excellent!!! PS Do you actually have cigerette butts in the ashtray? That is a cool touch if I am seeing correctly.
Your specialist military, sci-fi, historical and real world site.
Thanks. I used a more fish-eyed camera to try and show more of the room. It's totally opposite of the POV used in movies in that era, I know. And, yes, there are cigarette buts in the ashtray. There's one thing that doesn't belong to the set, which I forgot to mention: the fedora hat (in the upper right corner) - which is a prop from "misc. clothing"...
May I suggest moving the radiator/heater away from the wall with the door... It might be more sensible to put it on a wall adjacent to the exterior of the building, or an interior partition wall. Sorry... it's just the architect in me that's spilling out here. Fantastic set! :o) Cheers! M
Mind Over Matter
"If you don't mind, then it don't matter."
:o) What about a couch? You never know when that blonde bombshell running away from a jealous boyfriend will need a place to curl up for a nap. :o) If you're open to suggestions, may I recommend that you put the heater on the wall below the wall hung lamp. Then you move the coat rack/hat stand beside the chest of drawers. If you flip the direction of your door swing (as indicated by the door knob), the door will then open "into" the room rather than towards the corner of the room and your light switch will become more accessible. A nice cordovan leather couch would look nice one the left side of that door. :o) Hope you don't mind all the critical input. These are only suggestions. You are on to a real winner here. :o) Cheers! M
Mind Over Matter
