Sat, Feb 15, 6:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: rendering in poser 4
bald3 ( ) posted Fri, 16 February 2001 at 8:57 AM ยท edited Sat, 15 February 2025 at 6:03 AM
Is there a way to avoid, as far as possible, the scale effect in rendering pictures. The anti aliasing is not sufficient, i've got always scale effect ( contours of the figures ), especially on the arms. Poser or Photoshop can correct this default ? How ? excuse my english, i'm french.
JeffH ( ) posted Fri, 16 February 2001 at 9:20 AM
I know what you mean, the edges appear pixelated even with anti-alias. If it's really bad I use a smudge or blurring tool. Most of the time I render to .TIF and use the mask channel to float the figure in a layer, then I feather the edges. -JH.
Styxx ( ) posted Fri, 16 February 2001 at 9:20 AM
Just select your camera (whichever one your using for the render) and turn the lens up to something above 80... I use 120mm lens.. this avoids the "fisheye" distortion. Hope that helps.. Happy rendering! Styxx
bald3 ( ) posted Fri, 16 February 2001 at 10:23 AM
JeffH, the feather option works fine, thanks a lot.
