Thu, Nov 28, 7:19 AM CST
Subject: Poser5rendering-probelms-with-both-fryfly-and-P4render
otsego_dead ( ) posted Fri, 08 July 2005 at 4:58 PM · edited Sun, 24 November 2024 at 4:41 PM
ok-everytime-i-render-something-with-either-Pa-or-P4-renderer,-i-come-up-=with-this.is-thewre-anyway-to-fix-this???
otsego_dead ( ) posted Fri, 08 July 2005 at 4:59 PM
i-meant-to-type-firefly ok-LOL
otsego_dead ( ) posted Fri, 08 July 2005 at 5:16 PM
sorry-it-chops-off-the-top-and-bottom-or-the-images-when-i-render-something
otsego_dead ( ) posted Fri, 08 July 2005 at 5:22 PM
this-is-the-poser-window
SamTherapy ( ) posted Fri, 08 July 2005 at 5:22 PM
Is your keyboard busted or do you have something against spaces? Anyhow, you need to set the render dimensions to match your document window size. Then, if you you want a bigger render, select "Constrain Aspect Ratio" and type a bigger number in one of the size boxes.
otsego_dead ( ) posted Fri, 08 July 2005 at 5:29 PM
and-the-render
Hawkfyr ( ) posted Fri, 08 July 2005 at 5:32 PM
Why-post-a-1137-X-1600 image-for-this-render-? T-o-m
“The fact that no one understands you…Doesn’t make you an artist.”
Mason ( ) posted Fri, 08 July 2005 at 7:20 PM
I-Don't-Under-Stand-the-question-=?-LOL
Hawkfyr ( ) posted Fri, 08 July 2005 at 7:46 PM
I-Think-otsego_dead-is-wondering-why-his-/-her-renders-are-cutting-off-the-tops-of-the-renders-.
otsego_dead ( ) posted Fri, 08 July 2005 at 9:12 PM
Yep-and-i-figured-it-out-apperently-in-poser5-if-your-view-window-is-747X759-you-have-to-re-size-it-to-the-multiples-of-that-size-like-i-wanted-it-3times-bigger-so-i-had-to-multiply-747x3-and759x3-so-it-wouldnt-cut-off thanx-for-taking-your-time
