Sat, Feb 15, 8:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: I need help (stupid question) :(
jacksilverburgh ( ) posted Sat, 09 July 2005 at 8:05 AM ยท edited Sat, 15 February 2025 at 5:19 AM
Attached Link: http://www.muskateergraphics.com/mgpages/poser.htm
Can anyone tell me how to use there textures? What should I do with them? I tryed some merging with body textures...but got only a weird looking skin... Thanks for help..
Acadia ( ) posted Sat, 09 July 2005 at 9:36 AM
It says that you apply them in your graphic program. I've never worked with "textures" in that way, but from the sounds of the description at the site open the skin texture in your graphic program, then open the "texture" too. Copy the texture over top of the skin texture and then save it as a DIFFERNT name. Then you have to use MAT Pose Edit, to make the required files so that you can use the newly created texture in Poser.
jacksilverburgh ( ) posted Sat, 09 July 2005 at 9:46 AM
Ok thank you, I'll try that... Is Mat Pose Edit a program or just a term?
nickedshield ( ) posted Sat, 09 July 2005 at 10:04 AM
Mat Pose Edit is program. You do not need it in order to use the new textures.
jacksilverburgh ( ) posted Sat, 09 July 2005 at 10:13 AM
alright..thanks
randym77 ( ) posted Sat, 09 July 2005 at 4:30 PM
Are you sure you're using the textures with the right figures? It looks like they are "unimesh" textures. You use them on DAZ's generation 3 figures: M3, David, V3, etc. They won't work on the figures that come with Poser.
You would use Photoshop to layer them over whatever texture you wanted to use as skin, then apply the new texture in the material room.
If you post an image of the results you got, we could probably tell where you went wrong.
