Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Congrats again, Paul. This one is a real time saver. Sure, you can apply the nodes manually, then fiddle with settings afterwards, but on a figure like V3, with lots of material zones, that can be a laborious undertaking. So this script really speeds up the process, and is very very simple to use. Using occlusion nodes, in my opinion, is a better choice than using the overall occlusion method on the diffuse IBL light itself. It provides much more control over how the AO will affect your scene.
Tools : Â 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
Lululee, it defaults to the settings it thinks are right for the figure you are using.....which are the defaults that are mentioned in the tutorial. It assumes you want AO nodes on all skin parts, but in practice you only add AO nodes to materials that you think will benefit from it (ie. are wearing clothing, or are touching another surface/skin), to minimise rendertime. For example, if your V3 figure is wearing a necklace, only add AO ao node to SkinTorso. If your figure is sitting on a seat, only add the AO node to the seat material. After a while, you see a scene, and can quickly say, "I need an AO node there, there and there". (getting well OT here) For example....http://www.renderosity.com/viewed.ez?galleryid=984974, richardson has put AO nodes on all her skin materials, plus the stool mat, plus the floor. I personally would have left the nodes off her hand materials (since that is giving shadows in her figures). In http://www.renderosity.com/viewed.ez?galleryid=993858 (probably the best Poser render I've ever seen!), it looks like Uwe has used the AO nodes just on her skin - specifically her SkinShin (for the subtle boots shadow) and SkinTorso/SkinHip to provide AO shadows on her skin from her barely adequate clothing. At http://www.renderosity.com/viewed.ez?galleryid=980297 there is a classic necklace exmaple from Deane. An AO node on SkinTorso.
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Ariannah, we are unsure at this stage.
Creator
of OctaneRender
for Poser
Blog
Facebook
PBM, all the node setup's in the tutorial will work on both standard mat pose setups and RealSkinShader/HyperReal/Realism Kit shader systems. Not too sure what you mean by won't some of the same of the nodes on the main panel be the same? .
Creator
of OctaneRender
for Poser
Blog
Facebook
Creator
of OctaneRender
for Poser
Blog
Facebook
PBM, usually takes a day or so for products to be migrated across to the CP. I'll post here when I see it over there.
Creator
of OctaneRender
for Poser
Blog
Facebook
PBM - at the CP at http://www.contentparadise.com/user/product.php?productid=12305&cat=1325
Creator
of OctaneRender
for Poser
Blog
Facebook
How many lights? For the promo shots? Pretty much all my indoor studio lighting type renders are a main light at around 45 degrees elevation (80-100% intensity), and filler light positioned exactly at the camera (around 30-40% intensity) and a plain white IBL at around 30%. Sometimes there is a rim light in there too.
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.users.on.net/~pkinnane/AO%20Tutorial/AO%20Node%20Tutorial.html
A tutorial with some pretty pictures with everything you wanted to know about the Poser 6 Ambient Occlusion node but were afraid to ask.Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
