Thank's for the quick response. No, think the groups are ok. Now I have the correct phrase of the error-message No Geometrie refers with the "anchor-point", *.obj. It appears during the conversion of the *.phi file. The result is, the figure is complete after the conversion but the some details of the objects are not shown in the Poser frame. I found the same word (Achor-point) in Poser -> ... -> Import -> Wavefront OBJ. -> options for import -> row 5 Thank's again Matthias
Hello Jeff, yes indeed, one of the group didn't match exactly. But it didn't solved the problem. Nevertheless I found a solution to fix this problem: - Loading the whole *.obj as object into Poser - Exporting the same as *.obj out of Poser (tried several option settings) - Importing it into RDS 5.02 - revised the object - build a new *.phi - then an import of this *.phi was possible in Poser. Don't know why! Think the problem started with deleting some groups of the origin *.obj in RDS. As I said, the origign was created in 3Dmax. At last let me say I learned a lot by studing this Forum. It's so fascinating to create models in RDS and setting them to live in Poser. Some months ago I had no chance to do this, because the manual from metacreation is not very freshening. The real tricks and tools are coming out of this group. If I have some good stuff for this group (now I create a comic strip for a friend, topic a story underwater, created in RDS,Poser,Bryce)I'll upload it. Thanks again Matthias from Germany
Attached Link: Error in Poser
I'm a little bit in trouble. - try to create a model in Poser 4.0.3 (Windows) German Version. - Using the programm (convert hierarchy) by importing a *.PHI inside Poser. - This *.PHI refers to an *.obj, created in 3dmax and revised in RDS 5.02. Error message (hope the translation is correct) in Poser: Error: The anchor-point(s) does not belong to the following object: *.obj I don't know, if this error massage is a problem of Poser or a problem of RDS. Hope you can help Greetings Matthias
