Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
This is why files should be given unique names. If two files have the same name, Poser will just grab the first one it finds, even if they are in different folders or different runtimes.
To fix this...I would change the name of the OBJ to something unique, then change the refereces that call it (in the CR2 or whatever).
No, Poser cares for the path as long as a) the path is correct b) a file with the same name wasn't loaded before If the path isn't correct, it'll look anywhere in the runtime and pick the first file it finds. If a file with the same name was already loaded before, it'll take that one and just ignores the path. (That's true for P5 and P6 at least.)
For some reason the reference to a geometry file has made a turn left (or right) and when I load this prop I end up with a total different model, it has the same name but is in an entire other folder. I still have the original obj. file, can even import it into poser but poser refuses to load it and comes up with the other one. By the way, it always worked fine untill now. I can load the prop in DS so nothing wrong with the obj. How can i correct this annoying problem. Your help is much appreciated.
