Forum Moderators: RedPhantom
Yes very easy to set up. Just plug it all in and set the desktop prefs.
I'm using a Radeon 9800 - I think most of the top end ATI's feature dual monitor If you have the necessary vid card and extra monitor, is this kind of thing hard to set up? Morphy - just plug them in and go, I know the ATI comes with software for the purpose, but it's not really needed as Windows supports dual monitors natively, the hardest thing is working out which monitor to make your primary :) I also would never go back to a single monitor again...
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
Not silly at all. I think you can just add more video cards and monitors and add as many as you want (Up to nine I think under Windows XP) Hell I could add more if I wanted to but I'm too lazy to go find my extra cards and drag the old monitors out of the shed...lol Tom
“The fact that no one understands you…Doesn’t make you an artist.”
How weird! I just bought a new machine and monitor, and I never even thought of doing this. I currently have 2 machines and 3 monitors. The primary machine has 2 monitor outlets and it has an Nvidia 6600GT, so I guess I'm good to go. Heh, heh. I'm off to try this out. Thanks for posting. Otherwise I'd gone happily on using one monitor. mac
Mac,...you will happily use a dual setup and find scenarios that you never thought of that will be helpful to you. PhotoShop,for example...I drag all the tools and pallets to monitor 2 and have an un-obstructed workspace. You will find,if utilized correctly, that your workflow in many apps will improve. Ever had the frustration of toggling back and forth while doing(or writing) a tutorial? Well worry no more, keep the tutorial on one monitor while you work on the other. It's great for building web pages too. Drag and drop between monitors is an adventure in efficiency. Have fun. Tom
Hmmm.... I've been doing some net searching on this. Nvidia has NO help at all on the subject, and I can't seem to find what I want to know. The pages I googled were all about TVs, games and DVDs. Basically, what do I need to do? Plug in the 2nd monitor and reboot, then shift screens around? The 6600GT has dual-monitor support, but I don't want to make some stupid blunder with a brand-new machine. mac
In Windows, when you have two monitors plugged in, your display setup window will look something like this. You can move the second monitor icon around and place it where you want it to "connect" to the first monitor. Here you can also control what resolutions and other settings you want for each screen.
As far as gaming,....it may be the way the games resolution defaults. fiddle with the games settings first and then the video cards driver. There are some games I can not play because my card does not support 800 X 600 resolution. Which sux because I really wanna play Star Craft. Tom
You can also stretch your desktop to fill both (all) monitors, but I don't recommend it. I only turn on the second monitor when using applications setup to utilize them or things need to be dispersed a little to retain sanity.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
OK, people. I'm set up, but I have a question. I've set 'horizontal span' in the Nvidia propeties. This just doubles my screen to 2560 x 1024. There's another option called 'dualview' which I haven't tried yet (requires a reboot), but the horizontal span is a bit of a pain. All the default dialogs open in the split between the 2 screens. Yep, I can move them, but frankly, I couldn't be bothered with doing that 10 hours a day. It looks cool at first, and maybe it takes a bit of getting used to, but I've tried a few apps and I'm beginning to wonder if I don't prefer a single monitor. I'm going to try 'dualview' now. Will let y'all know how it looks. mac
Thanks, khai. I've got it now. Just as you say, dualview splits it into 2 areas. Much better. The horizontal span was way too confusing. I figured out that by using the restore (non-maximised) setting on apps, I can move them to the 2nd screen, so I can arrange my workspace the way I want. Yep, I have to say it..... pretty cool way to work. Thanks for the help, folks! mac
Nope. Video cards have nothing to do with rendering. Rendering is all done on the CPU and in RAM. Maybe adding the second monitor caused a different set of drivers to run and removed some sort of HAL contention (?).
off.
-- Bjarne
Stroustrup
There's a thread over at Daz called "Show your Workspace" in the common section... with some pretty cool home setups - one with a tri monitor setup. The hardest thing for me with duel monitors was making a cool enough wallpaper images. I'll post mine later tonight. Doug
I came, I rendered, I'm still broke.
Okay, I have two monitors and a geforce 5200 card capable of doing the job. I've got it all hooked up and set to dual mode. Problem: Poser doesn't want to work with it. The toolbars won't move over to the 17" at all, only thing I can really move is the document window, the library and perhaps the H.editor and joint editor (haven't tried but I imagine I could) So the ideal solution then would be to move the document window over to the 17" but when I do, there is no longer a display. It just blacks out. I'm guessing that monitor number two has no direct X. Is this the problem? -WTB
Agreed with all of the above: I've run dual monitors at home for well over a year now, a 20" main and an older 17" beside that I use to hold my tools for apps that support it, some apps that always open there (like Winzip and Winamp), and that I throw a second browser window or document on when I need it. I just ordered a new computer that will come with a 20" flatscreen, so I'll run the 2 20s. We run desktop replacement laptops at work and I'm agitating to make sure the next one I get runs dual outputs. Just because of the work I do, I spend a ton of time comparing documents and right now, when crunch time comes, it's often faster for my to bring the files home and work from there just in terms of the reduction in scrolling and window-flipping that has to go on.
I realized that my video card can use two monitors, and I happened to have an extra 14" flat screen laying around, so there you go....
It makes working in Poser so much better, one screen for the layout window and the little screen for all the tools. Way cool! ;)
