Tue, Feb 4, 12:36 PM CST
Forum Moderators: Staff
Subject: poser vs max 3.1 help please
Nifft ( ) posted Wed, 14 February 2001 at 3:48 AM ยท edited Tue, 04 February 2025 at 10:02 AM
I use max 3.1 and poser in a friend's studio where he have the two programs ( i use it in a pc that he use for "playing" (is a athlon 900 with a geforce1) he have buyed poser pro pack, and it won't work with Max,i don't know why , i explain: i try to load the test file in Max, Max load universe, when i try to load the scene max load a box, then when i scale.... compare that: an error was occurred the, and max close..... could be the Geforce? or is a known bug? hem any suggestion?
Karaneli ( ) posted Wed, 14 February 2001 at 3:03 PM
I had the same exact problem. What you have to do is uninstall poser, reinstall it, but DONT update it to poser 4.0.3. then install the pro pack then install the 3dstudio max plug in, it should work but only with the poser figures, other figures might still make it crash
blud ( ) posted Thu, 15 February 2001 at 11:21 AM
After doing the reinstall, I had no problems with any figures - this includes stuff that I did in max exported to poser and brought back into max as a figure.
Karaneli ( ) posted Thu, 15 February 2001 at 12:40 PM
really blud? I'm still having problems with some of my zygote figures (the knight and the bear) any idea what could be cuasing this?
really blud? I'm still having problems with some of my zygote figures (the knight and the bear) but my origional poser figures work fine.
blud ( ) posted Thu, 15 February 2001 at 4:32 PM
What's the problem. Do those figures cause max to become unstable or do they not look right in poser (missing faces)? I don't have either of those figures so I can't experiment with them - could be the cr2, the ppp has shown some deficiencies with "parsing" the pz3 as reported by CL. The area to look for are the empty "g" (group lines) in the cr2 (mason found this) add a name after the "g" - it might help max's ppp plug-in
Karaneli ( ) posted Fri, 16 February 2001 at 7:56 AM
ill try it, but how do i open the cr2 file, in just any text editor?
blud ( ) posted Fri, 16 February 2001 at 8:36 AM
Yeah, any text editor will do and then do a search for "g".
Rod Madic ( ) posted Mon, 19 February 2001 at 4:46 PM
Hey guys, I have just gotten Poser 4.03 and would like to get Poserpack.When I create a character in Poser and Propack will I have a problem exporting my Poser model to Max 3.1? 3DS or OBJ which is best with or without textures to export into Max 3.1? Thanks very much....
blud ( ) posted Mon, 19 February 2001 at 5:44 PM
Without the propack, you'll need to ge the habware importer/exporter plugin for max (http://www.habware.com/duck.htm) - be careful about scale, the obj file imports real small. The 3ds option works well as well - please note, when fussing with textures use the "picker" to select the mesh and a multi sub mat will pop up - you'll need to apply the texture to each category. The PPP links the scene and eases the pain of textures, more than likely though you'll have to reinstall poser without the 4.03 upgrade - the ppp does this
