Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 17 3:50 pm)
Looks good, but could you explain what the difference is between this and the 'Hot Leather Dress' in your store, apart from the length please?
Hi Lilybelles The Hot Leather Mini is very similar in design to Hot Leather Dress with these differences. 1. Overall length is much shorter. 2. The Mini's back has no leg split up through the back nor leather strap as the Hot Leather Dress does. It has been sealed over with a new set of seams. 3. The Mini has new leg spits up along both sides of the Dress Hot Leather Dress has solid seams. NOTE: these differences are in the .OBJ model structure and not create by bump or trans maps. Dale MacMullin
![file_275641.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_275641.jpg)
**Hot Leather / Mini Dress**Cernunnos Digital Creations is please to release the Hot Leather Mini Dress - the second of a new series leather themed conforming figures and texture packages for Victoria V3 to be used in P4, and P5 . This High Poly figure will be sure to add that realistic look to your renders. All Cernunnos products are 100% original work.Gallery Works Created Using This Product:
None at this time
The Hot Leather / Mini Dress for Victoria V3 contains the following:
Please Note:
Mini Dress and corresponding bump maps - dimensions (3000 x 3000)
Mini Dress Hardware Refection maps - dimensions (512 x 512)
HSL- Mini Dress Conforming Figures (Cr2 and Object)
1 Hot Leather / Mini Dress
HSL - Mini Dress Morhph Targets
Mini Dress Hip Only
R Leg Forward
L Leg Forward
R Leg Backwards
L Leg Backwards
R Leg Side
L Leg Side
R & L Buttock Bend
Hem Lenght
Sit Down
HSL - Mini Dress Maps/Mats**
2 Black Leather Mini Dress Map/Mats
1 Red Leather Mini Dress Map/Mat
1 Balck & Red Leather Mini Dress Map/Mat
1 Brass Refection Map
HSL - Mini Dress Bump Maps*
1 Mini Dress Bump Map
HSL - Mini Dress Trans Maps
None
** Bump maps for P4 are in jpg format and will need to be converted as part of the installation process.*
