Fri, Jan 10, 6:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Render Problem with Poser5 files in Poser6
Sivana ( ) posted Sun, 24 July 2005 at 9:24 PM ยท edited Fri, 10 January 2025 at 6:08 PM
Hi everybody, I want to ask if all Poser6 user have that problem that firefly cant render the Poser5 textures? My result always is a porcelain-white body and/or face and all aditionals (by sample lipstick or bodygloves) are black only. It always seems ok when I fit the character but after rendering $& only. Yes I have the update No1 done. Perhaps someone can give me an idea whats happen or if others have the same problem. Andrea
thefixer ( ) posted Mon, 25 July 2005 at 1:50 AM
Sorry haven't seen this one [yet!], add to the "growing" list of problems still! thefixer, poser coord.
Injustice will be avenged.
Cofiwch Dryweryn.
destro75 ( ) posted Mon, 25 July 2005 at 5:08 AM
Sivana, have you looked at the Mat room? I have a feeling there is quite a bit going on in there in P6 from P5. See if some nodes got disconnected. That may be part of the answer. Thefixer, there is a posting, now dropped to page 2 about the whole bucket issue. It was quite a conversation thread. Check it out when you have a moment! Hope this helps!
randym77 ( ) posted Mon, 25 July 2005 at 5:40 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2187315
Are you using the skin shader node?
P6 changed the way the skin shader node works, so P5 settings don't look very good any more. :-(
richardson ( ) posted Mon, 25 July 2005 at 7:03 AM
Some textures cannot be "found" in P6. Especially special textures like SP3/V3 hybrids. You'll have to reload them by hand in the matroom.
Sivana ( ) posted Mon, 25 July 2005 at 8:15 AM
Yes that was the problem. Thanks very much for your help! Andrea
atomoid ( ) posted Tue, 26 July 2005 at 4:18 PM
Its hard to determine which of the above posts fixed your problem. Please let us know what worked. Thanks! If the problem was merely missing textures, you should be able to fix that by Add the Poser5 runtime (and any other libraries you had linked in Poser5) to the Poser 6 library, then it should find them when you open up in Poser 6.
Sivana ( ) posted Tue, 26 July 2005 at 5:46 PM
I think I have both problems. The images showen in the thread from the link with the shader nodes, I know very well but also (most characters)missing textures. Anyway, with "Honshu Dreams" I had the textures showen in the preview, but after rendering there was white face with black lips and eyes only. Well in the moment I have "fixed" the problem with changed files only. I have filled the runtimes with Propack (if there) or Poser 4 files again. That works very well ;-) Perhaps not a professinal solution but a quick one.
