Mon, Feb 10, 3:46 PM CST
Subject: Exporting an object from Bryce 5
oliveramberg ( ) posted Mon, 25 July 2005 at 3:08 AM · edited Sun, 19 January 2025 at 5:32 PM
Hi! I need to export an object from Bryce 5 into a format which can be handled by Cinema 4D. I try to use the function export an object but it's allways disabled. Is there a way to do the export. I attached a sreenshot to show what I mean. Thanks for your help! Cheers Oliver
draculaz ( ) posted Mon, 25 July 2005 at 5:18 AM
Bryce only exports terrains and lattices. ungroup everything, press the E thing above G. Ctrl-D or Ctrl-E, I forgot. and then you'll be taken to a separate menu where you can choose what to export it as and with what detail. drac
oliveramberg ( ) posted Mon, 25 July 2005 at 5:21 AM
Thanks Drac. Unfortunally some the "R" which contains a negative cube to cut the bow of the "R" won't show an "E"...
shinyary2 ( ) posted Mon, 25 July 2005 at 9:13 AM
Then you can't export it. The best thing to do would be to export it from Bryce and then import it into a mesh editor, such as Wings3D or Blender, and fix it there. But Bryce simply will not export booleans, I'm afraid. =)
Incarnadine ( ) posted Mon, 25 July 2005 at 10:37 AM
or just build it in cinema?
jelisa ( ) posted Mon, 25 July 2005 at 4:13 PM
Or use Elefont to generate the letters and import into C4D.
Incarnadine ( ) posted Mon, 25 July 2005 at 4:31 PM
What version of cinema are you working with? Since 6 or CE+ there is a text spline tag which when dropped into a spline extrude object will give you exactly what you are looking for. The text spline generates automatically for the entered text in either postscript or truetype fonts.
oliveramberg ( ) posted Mon, 25 July 2005 at 11:25 PM
I use Elefon often. But in this case I had to manipulate the "R" with a negative cube. After this the "E" didn't show up anymore. I don't have Cinema only Bryce 5.
Zhann ( ) posted Tue, 26 July 2005 at 12:25 AM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=552
You can also use a paint program for a heightmap and then a terrain in Bryce and export as an obj or 3ds, etc. Check the link 'Creating 3d text in Bryce'
Bryce Forum Coordinator....
Incarnadine ( ) posted Tue, 26 July 2005 at 8:51 AM
Ah, sorry, I thought you did from your original post. What is the font, perhaps I can help with a native C4D object. Or Zhann's proposal works well too.
Fo3 ( ) posted Wed, 27 July 2005 at 1:03 AM
Why not just use Anim8or? That's one freeware we ought not to ignore!
What is a CRIF?
