In my time as a Marine Mechanic I used that copper stuff on loads of machines. It stops nuts&bolts seizing at temps upwards of 1000f, but it was very pricey stuff.
Congratulations by the way with your win of the Renderosity graphic contest! Fantastic entry!
"My PC has been acting up the last few months. It would lock up if I looked at it crooked." Rod: I would recommend not doing this. How would you like it? :^)
Skiwillgee: It might cost $6 now...I was in the Merchant Marine in the 1970s...........
My PC has been acting up the last few months. It would lock up if I looked at it crooked. So I started to investigate, read all that I could, tried a bunch of Software related sudo fixes. Finally I tore my machine apart yesterday and what did I find? The Heatsink compound was one of those silly stick on types (all dried up), I cleaned all that crap off. Now you're suppose to use Silicone heatsink Compound, Yet I researched quite a bit & found out you can use a Copper base Anti Seize like Mechanics use, it has the same consistancy, a bit grainier but much better heat properties. It just so happens that I had some in the garage. Installed everything, went into my CMOS & dropped my memory access to safe mode(which was probably the culprit for the lock-ups). Damn thing runs like a tank(tried like hell to make it crash), a tiny bit slower, but it's worth the trade off. ICM
___
Ockham's razor- It's that simple
