Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Looks interesting. Much more interesting than with ropes :D
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
Poser 6's cloth room is great, I can put all kinds of dynamic clothing on just about any figure I want to. Or even the object files of a lot of conforming clothing. No offense to the makers of Wardrobe Wizard, but with Poser 6's cloth room, I haven't found a need for it. Plus the clothes flow better in animations than conforming clothes do.
Do you P6 users have any troubles using Eroko? I find it doing weird things to my P5, such as locking the document window when I delete the figure, and changing my startup settings. I heard Pro users having trouble also. I tried to load the cr2 into DazStudio. I got an error message: .... Reading EROKO_The_Masochist.cr2 No joint parameter name was specified on line 77503 in C:/Program Files/Curious Labs/Poser 5/EROKO/Runtime/libraries/character/EROKO/EROKO_The_Masochist.cr2 C Exception: Memory Access Violation Failed to import C:/Program Files/Curious Labs/Poser 5/EROKO/Runtime/libraries/character/EROKO/EROKO_The_Masochist.cr2 : 12f24c The memory access violation Eroko causes in DazStudio smells very much like the sort of problems I have with P5, exept that P5 (sadly) does not produce a log file. Are there tools to scrutinize a CR2? Too bad, this. Eroko would be a very attractive addition to that weird bunch living in my runtimes. B.
Casette, I'll try that one tonight to see what's up. After I watch the new season of Tripping the Rift. Jules53757, same one as you, but I wanted to make a wardrobe for her. Eroko can't just hang around all day doing the same thing.LOL. EnglishBob, closer than you might think. V3 radial is bigger but everything is kind of in the right place. I reduced Eroko's xyz from 92-95%. I changed the parent of the dress to universe, that way I can reduce and move the dress to a close fit. Gave 10 to 20 frames to adjust and saved out as an .obj. Imported back in and saved as a prop ready for posing. The boots I bought from Daz so they could be by B-man. I just parented them and turned the shin and feet invisable and used mags to fit, trick. Fazzel, I do quite a bit in the clothroom too but like using the wizard as well. bagoas, yep. I'm thinking it's the Japanese names. I think we need someone to redo the Cr2. JP's on the hands are screwed, I wonder if the naming thing has something to do with tat also. Mind, modeling something that works fine in another app is a real pain to get to work well in poser.
I am running P6 on Win XP. I have to say, EROKO causes only a little prob when I say File new: Don't save. Instead of showing a new document window the screen is empty, I have to redo the file new. What I found not so nice is the texture, V2 body fits in general but not the head :(( Otherwise, what her name already expressly states, she does what I ask her to do ;)
Ulli
