Sat, Jan 11, 6:55 AM CST
Subject: production frame
markm ( ) posted Wed, 27 July 2005 at 4:31 PM · edited Sat, 11 January 2025 at 4:29 AM
Hi all . I am trying to render an image bigger than the preview window but it keeps getting cut off by the production frame in Poser 6 . Does anybody know of a way to adjust or get rid of it ?
DCArt ( ) posted Wed, 27 July 2005 at 4:42 PM
  1. Choose Window : Document Window Size. Set the dimensions so that the aspect ratio is about the same as what you want in your final render. 2) Choose Render : Render Dimensions. In the Render Dimensions Dialog, check the Render to Exact Resolution option. Make sure Constrain Aspect Ratio option is checked, then click the Match Document Window button. After that, if you change the width or height value, the other value should automatically change to match the aspect ratio of your document window.
