Wed, Jan 8, 8:33 PM CST
Subject: Need Help with Injection Magic 1.1
graphixdezine ( ) posted Wed, 27 July 2005 at 10:39 PM ยท edited Mon, 06 January 2025 at 6:08 AM
I am trying to do my own morphs for the first time using poser 5 and v3..I have Injection Pose Builder (which I can't get to work either) and Injection Magic which will load to the end and then gives me me a runtime error 13..I attached a screen shot..has anyone run across this before and can tell me what I need to do..I can't find any thing in the help file for it... Thanks in advance
Neesa
Message edited on: 07/27/2005 22:39
mathman ( ) posted Wed, 27 July 2005 at 11:37 PM
I also have IM v1.1. Unfortunately, it's a buggy and unsupported program. I tried to get help with a similar problem (in my case, it was "Path Not Found"). Good luck if you can get help with it. In my case, nobody seemed to want to get involved. My advice is to learn how to do it manually.
Kalypso ( ) posted Thu, 28 July 2005 at 12:40 AM
Site Admin
mathman, I don't know if nobody wanted to get involved or if actually nobody really knows :) You see, Dark Whisper has refused to support it after selling it to DAZ and DAZ do not know enough about it to support it. I spent a few months trying to get some sort of support with no results. In fact, when I first got it it wouldn't even run and only when someone pointed me to a SR at Dark Whisper's site would it open. Dark Whisper himself didn't even tell me about that SR although it was hosted on HIS site! Your only hope is if someone with the patience to work on it and who has come across similar problems to yours can give you some advice otherwise it's pretty much just going to sit there on your HD like mine!
lululee ( ) posted Thu, 28 July 2005 at 8:07 AM
Does anyone have a clue as to what is the benefit to either Daz or Dark Whisper to still be selling a product that they give no support to.? cheerio lululee
graphixdezine ( ) posted Thu, 28 July 2005 at 8:29 AM
Well Thank you all anyways...maybe you can help with why when I load my cr2 into Injection Pose Builder it keeps parsing forever? LOL I can't get past that point. Thanks Neesa
bwldrd ( ) posted Thu, 28 July 2005 at 9:51 AM
Check your region settings. I had this problem with it and had to change some of the currency settings (don't remember now what exactly I changed, but know it was with the currency) after that, has worked just fine.
Consider me insane if you wish, but is your reality any better?
graphixdezine ( ) posted Thu, 28 July 2005 at 10:00 AM
Okay...but how would I do that? Thank you for your help! Neesa
graphixdezine ( ) posted Thu, 28 July 2005 at 10:08 AM ยท edited Thu, 28 July 2005 at 10:09 AM
awesome!! It worked..went to my regional settings..realized what you meant after I posted..LOL..and it worked!! Thank you sooooo much!!
Neesa
Message edited on: 07/28/2005 10:09
Omadar ( ) posted Tue, 20 September 2005 at 4:48 PM
Hey, I'm having the same problem - what did you do to fix it? What did you change in Regional Settings? Thanks
graphixdezine ( ) posted Tue, 20 September 2005 at 6:17 PM
I had to click on customize and I believe there was an extra space or something was wrong with the currency setting...I don't quite remember what I changed but I attached a screen shot of what my settings are..so hopefully that will help...I really like IM ..it works great!
Neesa
mathman ( ) posted Tue, 20 September 2005 at 7:04 PM
Where is the customize button ? .... I couldn't find it.
graphixdezine ( ) posted Tue, 20 September 2005 at 7:11 PM
see at the top on th eimage I posted, where it says english, under select and item to match its perferences, etc.... and there is a drop down menu..right next to that is the customize button HTHS Neesa
