Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Hi Stewer,
Thankyou very much for your help. I was getting there with a home grown python script to write the materials for my characters into a .mtl file. Your input has put the icing on the cake and I now have a complete .mtl file writing solution.
Unfortunately Poser 5 seems to be a bit mucked up internally as I cannot get the script to replicate the ordering and numbering of the materials that Poser 5 uses when it writes the wavefront .obj and .mtl files. I do not think this is a problem with the script but rather that Poser is not outputing the .mtl materials in a consistent way. There seems to be some confusion with parented props (e.g. Hair) but it is not predictable.
My research has indicated that you can now save the actual transprency map (if there is one) because Pose-Ray 3.8.11 handles these correctly. This is really useful for those transmapped eyelashes - and the like!
Now I probably need to get a Python programming book as the online documentation at Python.org is extensive but somewhat less than helpful.
Regards from Jovial.
Hi,
When I use Export from Poser 5 to Wavefront OBJ format
(in order to use PoseRay - because my latest scene will not render in P5!), there is a partner scene .mtl file created that seems to be written incorrectly.
If a scene had (for example) two victoria 3 figures and these had two different sets of textures applied, then the .mtl file is written with all of the material reference names for both figures as those for the last figure added.
This is probably best explained with a little example of the .mtl file:
but the .mtl file is written with
newmtl SkinTorso:1
Ns 19
Ka 0 0 0
Kd 1 1 1
Ks 0.066667 0.066667 0.066667
newmtl SkinTorso:2
Ns 19
Ka 0 0 0
Kd 1 1 1
and the same problem for all the other material zones.
So the first figure has now lost all of its texture references.
I was wondering if anyone had written a Python name mangler so that each internal material group name has (for example) the figure name or other unique id added into the name so that the export would work correctly.
I guess that this would be similar concept to the crosstalk killer but for material zone names.
Any help or suggestions greatly appreciated.
Regards,
Jovial.
