Fri, Feb 14, 8:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Can someone explain this little hair thing to me?
richardson ( ) posted Wed, 03 August 2005 at 12:57 AM · edited Fri, 14 February 2025 at 7:58 PM
It renders pure white. Shows in preview. Shows loaded in texture. Only thing is, it did not load onto a figure as I've imported the figure as an object. It's not ambient. I tried it at 1.0 and default 0.0
stewer ( ) posted Wed, 03 August 2005 at 1:54 AM
Turn up "texture strength" in the texture node to 1.0.
Spanki ( ) posted Wed, 03 August 2005 at 1:55 AM
I hadn't looked to see how it's supposed to be, but at first glance.... see that 'Texture_Strength' line item, at the bottom of the texture node? Shouldn't that be set to 1.0?
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Spanki ( ) posted Wed, 03 August 2005 at 1:56 AM
..or maybe the one on the trans node should be 0.0? (I still hadn't fired up Poser to look)
Ahh.. x-posted with stewer ;).
byAnton ( ) posted Wed, 03 August 2005 at 2:05 AM
hehe. Good eagle eyes there. I was thinking it might have been an out of memory instance but I missed the strength too. :)
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
richardson ( ) posted Wed, 03 August 2005 at 11:38 AM
Replies from stewer, Spanki, and Anton. Tuesday morning...duely noted! lol Thanks Yep Tex strength. Did not even look there. It loads this way.
Fazzel ( ) posted Wed, 03 August 2005 at 12:22 PM
No, Spanki, if the trans node were set to 0.0 then you would lose the effect of the trans map. It has to be set to 1.0
Kristta ( ) posted Wed, 03 August 2005 at 3:54 PM
bookmark
Puntomaus ( ) posted Wed, 03 August 2005 at 5:42 PM · edited Wed, 03 August 2005 at 5:43 PM
This happens only with the hr2 version in the Hair folder. The three Cr2s for Jessi, SP3 and V3 are set up correct. And setting texture strength to 1 fixes the problem.
Message edited on: 08/03/2005 17:43
