Sat, Jan 25, 3:59 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Poser Export to Rise
sama1 ( ) posted Wed, 03 August 2005 at 6:32 AM · edited Sat, 25 January 2025 at 12:03 AM
Attached Link: http://rise.sourceforge.net/cgi-bin/makepage.cgi?Home
I need help in writing a script to export Rise. What I am trying to do is write out the geometry of a model in Poser to the Rise format.
The Rise format starts with the letters "TRI" if the geometry is a triangle and "QUAD" if the geometry is a square.
The problem I am have is more of a Python question where I can print out a line at a time for each of the X,Y,Z coordinates. What I want to do is print them all out on one line.
Any help would be appreciated.
My main goal is to get a Poser character into Rise and find out if texturing works. If not textured, find out if I can use the techniques of Henrik Jensen's photonmap to add more realism to a character.
Thanks,
Sam
nruddock ( ) posted Wed, 03 August 2005 at 1:12 PM
The Python trick your looking for to get things on the same line, is to have a "," at the end of the print statement.
Assuming you've managed to get to the point where you have a Geometry object (if not just say so), you want something like this :-
verts = geom.Vertices()<br></br>sets = geom.Sets()<br></br>polys = geom.Polygons()<br></br>for poly in polys:<br></br>    start = poly.Start()<br></br>    numv = poly.NumVertices()<br></br>    if numv == 3:<br></br>        print "TRI",<br></br>    elif numv == 4:<br></br>        print "QUAD",<br></br>    else:<br></br>        print "HELP",<br></br>    for idx in range(start, start + numv):<br></br>        vert = verts[sets[idx]]<br></br>        print vert.X(), vert.Y(), vert.Z(),
sama1 ( ) posted Thu, 04 August 2005 at 6:48 AM
Thanks for the pointer. I would never have thought of putting a comma at the end.
nruddock ( ) posted Thu, 04 August 2005 at 2:52 PM
It's mentioned in the Python documentation for the print statement.
