Tue, Nov 26, 7:39 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: How to change a figure's material zones?
zulu9812 ( ) posted Fri, 05 August 2005 at 6:36 AM · edited Tue, 26 November 2024 at 7:27 AM
I imagine that this question has something to do with UV Mapper. How do I change/add material zones on a figure?
byAnton ( ) posted Fri, 05 August 2005 at 7:37 AM
I assume you mean to actually add/remove/alter the material zones, oppose to changing colrs etc. Yes you use an app, like UV mapper, that can reassign materials to polygons. In UVmapper. 1)Open the obj 2)Select>Mataerial> you chose 3)Assign>Material> You chose 4)Save To make new materials on various polygons 1)Open the obj 2)Exportuv's>Save out Uv's for later 3)Select Poly's/remap/do whatever you have to to get the polys you want on your custom material into one area 4)Assign>Material> You chose 5)Unselect 6)ImportUV> Apply Uv's you saved out to restore the mapping 7)Save Obj may be fragmented which can cause issues with firefly Use SPanki's free STOMP utility (See PIC) 1)Open obj 2)Save out OBJ 3)Unselect mtl checkbox 4)Select "By Materials" 5)Save Hope that helps. Anton
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
PhilC ( ) posted Fri, 05 August 2005 at 9:21 AM
Within Poser you can also use the grouping tool.
zulu9812 ( ) posted Fri, 05 August 2005 at 10:13 AM
aye, but isn't that restricted to the body parts?
PhilC ( ) posted Fri, 05 August 2005 at 10:21 AM
You can select any polygon on the figure and assign it to a new material.
zulu9812 ( ) posted Fri, 05 August 2005 at 11:54 AM
Really? Is that in the setup room? I never knew that...
PhilC ( ) posted Fri, 05 August 2005 at 12:34 PM
You can do it in the Pose Room.
zulu9812 ( ) posted Fri, 05 August 2005 at 12:43 PM
aah - cool, thanks. And thank you Anton as well - I'll give both a try and see which one I prefer.
kobaltkween ( ) posted Fri, 05 August 2005 at 3:04 PM
just to satisfy my curiousity- i'm assuming anton's way means that every character referencing that .obj file will have the new material. phil, am i correct in believing that using the group editor would mean the new material would only apply to that file or that character if the figure was saved to the library?
an0malaus ( ) posted Sun, 07 August 2005 at 2:58 PM
I've just been through this exercise recently and thankfully (being on a Mac) the latest version of UVMapper X does the very thing I needed to do. Having started with the DAZ Morphing Cat Tail, I wanted to add more bones/parts to make it more flexible. It was easy enough to add new bones, but I want to have the new object as an obj file, rather than bloat the cr2 file with custom geometries for each part. I could not find a way to successfully export the parts and have it look anything like the original obj file (which I wasn't moving any vertices or redefining faces, just changing the groupings). In the end, the solution was to take the original obj into UVMapper, save the UV map, select the faces and assign them to the new group names, then export the model. After that, I can just point my cr2 with the new bones and joint information at the new obj file that UVmapper generated. A spot of hand coded, Ajax style Easy Pose JCM and I now have a 15 segment tail, rather than the original 8. I didn't need the original morphs which was lucky as that would have added complexity trying to preserve them in the regrouped mesh.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
