Thu, Nov 28, 7:38 PM CST
Renderosity Forums / MarketPlace Showcase
Welcome to the MarketPlace Showcase Forum
Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 27 6:56 pm)
Welcome to the MarketPlace Showcase Forum. The Showcase Forum and Gallery are intended for all commercial related postings by active Renderosity MarketPlace Vendors only. This is a highlight area where our membership is invited to review in greater detail the various art products, software and resource site subscriptions available for purchase in the Renderosity MarketPlace.
Subject: Terraformers fantasia
cyllan ( ) posted Sun, 07 August 2005 at 3:12 AM · edited Thu, 28 November 2024 at 5:08 PM
Attached Link: http://http://market.renderosity.com/softgood.ez?ViewSoftgood=39656
New in the Terraformers series of morphing landscape figures is the Fantasia pack, providing an almost infinite variety of landscapes, both realistic and highly surreal, for your characters to walk through or pose against.
The Fantasia pack contains 3 high resolution figures. Each contains a variety of fractal and math generated morphs that can be used to create an almost infinite variety of scenes, along with 14 different textures ranging from the realistic to the fantastic, a bitmap, and a new reflection map.
CentreMount is a single morphing mountain/outcrop, with the morphs Brain, BrokenPyramid, CastleRock, CragRing, Crags2, Eroded, FourCorners, Ledges, Ledges2, LobedMount, Mountain2, Petals, Pyramid2, RiftColumns, Rifts, RoundCracked, RoundRocks, SideRift, SpikeCity, SpineMount, Spires, ThornMount, Torus, and Volcano.
RockCluster is intended as a lower, ground plane, although the morphs can be used to create higher altitude scenes too. The morphs are Level, ConeHills, Cracked, ErodeRaise, Erosion, Pitted, Ridges, ErodeFromSide, ErodeStrong, Intersects, Ranges, SpikeTop, SpikeHalo, SpikeHaloLow, SpikeHaloOnly, SpikeAll, Roughen, Terrace, Rift1, Rift2, RiftMountain, SpikeRidges, SpineRidges, RidgeGround, TableMountains, StepSpires, Spires, SpiresStrong, UnevenErosion, Mountain, and Mountain2.
The Fractal figure is slightly different in usage from the other two. While the rock cluster and centre mount figures have morphs based on the same general topography, so that when several morphs are used together the effects are (roughly) predictable, the fractal figure contains 24 different complex fractal landscapes loaded as morphs. Each of these can be used on its own, by setting that parameter dial to 1 and the others to 0, or you can spin the dials to create unpredictable landscapes that are completely different. In addition to the landscape morphs, the Level morph will flatten out the landscape (or turn it into a valley if you pull it far enough). The fractal landscape morphs are: Causeway, CentreComplex, CentreTeeth, Circular1, Circular2, Crags, Crater, Chimney, Complex, DragonTeeth, ErodeMount, ErodeStack, FrameCliffs, HighSmooth, MountainValley, Outcrop, Teeth2, TwinPeaks, Trifle, Spires, Volcanic, Walls1, OneWall, and Ziggurat.
cyllan ( ) posted Sun, 07 August 2005 at 3:16 AM
cyllan ( ) posted Sun, 07 August 2005 at 3:17 AM
cyllan ( ) posted Sun, 07 August 2005 at 3:20 AM
