Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
UHhh, I downloaded the "art" piece, but I do not see how this works with Genzo. The assorted anatomical pieces would work with Aniko or Eroko, but I do not see how to incorporate them. Am I missing something? Is there a hidden message that links things? Some of the Japanese Poser humor I do not understand. Thanks, -The Starkdog
First mark the bullseye and delete it. Click on one of the remaining parts, set its dials all to reset and you will see what it is. Export this as Wavefront obj. Make sure you uncheck everythin in the hierarchy window except your obj. Uncheck all export options except "Morph target". Save it wherever you want and then delete it from the window. Do so for the rest of the bunch. Once you will see something like a joystick for Genzo. Save this as a prop. When you saved everything and your window is empty, load ANIKO and load the saved morphtargets to her hip, one by one. Save this figure as Aniko_complete or so. Thats it.
Ulli
Attached Link: http://www.k2.dion.ne.jp/~have/hondara7.htm
Have has a wonderful character created, Goblin. The hint, there are some props invisible, additional horns and a "tool" called mara. Make it visible and you will be impressed ;) A real monster!! (WARNING ADULT ONLY !!!)Ulli
