Take the machine into safe mode (press F8 the moment the machine starts) and run AVG from there. Also download Spybot Search and Destroy and Ad-aware and run them as well. If the tojan is one of the coolwebsearch variants run get and run CWshredder. All are free.
"AVG wiped out every .exe file on my hard drive." Never see any anti-virus do that before. Windows uses .exe's and if if AVG deleted these then windows wouldn't work. It probably wouldn't even load. So given this and your post (11). You have other technical problems. As you have to reinstall anyway. Backup then format the drive, run scandisk and defrag to check for physical drive problems.
A couple of sites that may help you (hopefully virus-free).. http://www.iamnotageek.com/a/dl.exe.php http://securityresponse.symantec.com/avcenter/venc/data/backdoor.nthack.html It seems that dl.exe (and its aliases) don't attack .exe files, but hacks into your e-mail addys and the like (and other nasty vandalish things). So if your .exe files are infected it's with a different virus... Cheers, Diolma
I had gaelicum.a virus on my computer according to AVG and it clean them all and tolled me to reboot. It removed all the exe files on my computer when it rebooted. Every program is gone. I did have to reinstall windows. It not a total loss because I still have all my data but the program is gone. Like I have all my poser files but the exe file is not there. It removed over 2000 exe files so my computer will never be the same. Dale
Really sorry to hear whats happend to you Dale. But glad to to see you have backups. It seems regardless of whatever anti-vrus you ran the end result would have been a trashed PC. The gaelicum.a virus is really nasty. http://forums.techguy.org/showthread.php?p=2832313 reports... "particularly dangerous is that it appears to affect any/all exe files.once affected, it will probably require reloading of the infected exe or complete software reload." In addition, it appears to attack the exe files once you access the folder/directory. (it goes right in and grabs the exe files.) So, it very difficult to run anything .. as soon as you do, it gets infected. " Overall, get your data off, wipe the machine and re-install.
For once Im not blaming E-on for my troubles. But it seems that my computer has caught and nasty bug call dl.exe. Its not going away because I think it is on my pop sever and every time I down load anything this little guy is hopping a ride. I have been doing a lot of downloading from e-on and other sources. Could you run a scan by just file search and see if you gotten it too?
Dale
