Sun, Feb 9, 5:25 AM CST
Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Subject: HOYA CPL
MaydaMason ( ) posted Wed, 10 August 2005 at 12:52 AM · edited Sun, 09 February 2025 at 5:19 AM
good morning!!! i've a big doubt... i've to bought another cpl for my new cam... (astep down ring create a vignette just with cpl), i've decided for hoya products... but (at ebay) i've seen a lot of cpl of hoya... green, brown, blue and black package... someone know the difference? or someone of you has a performing hoya cpl? thanks for your answers about my doubt! may
Mayda
MaydaPhoto
gradient ( ) posted Wed, 10 August 2005 at 1:23 AM
Here's a chart that shows the difference. http://cgi.ebay.com/Hoya-SUPER-PRO1-Circular-Polarizing-Filter-52mm-CPL-52_W0QQitemZ7536274207QQcategoryZ74915QQrdZ1QQcmdZViewItem# Sorry, it wouldn't let me put the whole link in....just copy and paste....
In youth, we learn....with age, we understand.
DJB ( ) posted Wed, 10 August 2005 at 1:34 AM
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
gradient ( ) posted Wed, 10 August 2005 at 1:35 AM
That's not the whole link....
MaydaMason ( ) posted Wed, 10 August 2005 at 1:38 AM
maybe the black pakage contains the best cpl? 7 layers? may all this layers make the time of exposure more long? i'm very confused... i've bought another cpl some time ago... and create shots with a warm tones... i desire to dark the sky and keep the same colours...
Mayda
MaydaPhoto
gradient ( ) posted Wed, 10 August 2005 at 1:54 AM
Attached Link: http://www.hoyafilter.com/index.html
@dBgrafix....sorry, you're right link does work. @mayday...I have attached the link to the Hoya site...maybe that will help some more. There are some other differences...yes, more layers, but also thickness and whether it has double threads. I know more layers= more $....I am not sure if it is worth the money though. Maybe someone else has some experience with the different types....
Onslow ( ) posted Wed, 10 August 2005 at 3:07 AM
I have and use the standard Hoya cir-polarising filter - very happy with it, no problems. The 'Pro 1' has coatings on it that are designed to cut down on flare and ghosting so should give a more contrasty picture. The figures and graphs that Hoya give are for the front of the filter so perhaps this is a problem if you want to use multiple filters at once. The most I have used is an ND grad(Cokin) and the polariser together and I have not had a problem with flare, ghosting or vignetting. The other difference they quote is the 'Pro 1' is a lower profile - again depends on how many filters you intend to use at any one time, also how wide the lenses are you intend to use it with. I don't think you would have any problem with normal wide angle, perhaps you would if you are going to the extreme wide angle. My feelings - the standard is suitable for all normal usage, get the Pro 1 if you are using the new generation super wide angle zoom lenses for C size sensors or any other extreme wide angle lens or multiple filter set ups.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
MaydaMason ( ) posted Thu, 11 August 2005 at 4:06 AM
it's hard! i've choosed for the light grey case... hope that my objective couldn't see it! the best is the black box with 2 filter attach and very thin... but it's very much expensive! thanks for your help!
Mayda
MaydaPhoto
