Mon, Dec 2, 6:19 AM CST
Subject: Displacement doesn't render in mirror
kyraia ( ) posted Wed, 10 August 2005 at 2:48 AM · edited Mon, 02 December 2024 at 6:18 AM
Maybe this is a known issue? As you can see above, displacements don't seem to render properly in a mirror. The sphere here has a very high displacment value, but the same is true for characters with realistic displacements values. Their mirror image looks like a zombie. Any suggestions?
stewer ( ) posted Wed, 10 August 2005 at 4:06 AM
Use a finer mesh. The raytracer can do only mesh level displacements, not micropolygons.
kyraia ( ) posted Wed, 10 August 2005 at 5:37 AM
The raytracer can do only mesh level displacements, not micropolygons. I see. Is this a bug or a feature?
stewer ( ) posted Wed, 10 August 2005 at 9:29 AM
It's by design. A REYES renderer breaks up your scene into millions of micropolygons, which is how it can do these fine displacements. Since all these micropolygons would not all fit in the computer's memory at the same time, only those micropolygons that are necessary for the patch that is being currently rendered are being created and deleted once they have been rendered. A raytracer instead needs access to the whole scene, as it doesn't know in advance what objects the reflected ray will intersect. To save memory, the raytracer gets to see only the base mesh, not the micropolygons. FireFly is a hybrid renderer, so it incorporates both a raytracer and a REYES engine. REYES is being used for the main rendering, and effects like reflection, refraction or ambient occlusion are being handled by the raytracer.
Mec4D ( ) posted Wed, 10 August 2005 at 11:14 AM
stewer Poser5 render the micropolygons as well in the reflection and this feature in Poser6 is a BUG, I try to use many displacement maps and not one relfect the displacement map correct in poser6 as it have to be... Cath
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
stewer ( ) posted Wed, 10 August 2005 at 1:12 PM
Really? I have to try that out.
ynsaen ( ) posted Wed, 10 August 2005 at 1:22 PM
salt (bookmarking)
stewer ( ) posted Wed, 10 August 2005 at 1:36 PM
A quick test in P5 SR4/OS X shows me this - it's mimicking displacement in the reflection with bump mapping, but it's not doing any fine displacement.
Mec4D ( ) posted Wed, 10 August 2005 at 3:01 PM
I don't have P5 here on my computer anymore and I found this one, I made series of the images with the same fur effect that reflect in the reflection, and used displacement maps... P.S why I don't get any notifications about replies from renderosity forums? somebody know what to do? I check it the ::Notify:: button
PapaBlueMarlin ( ) posted Wed, 10 August 2005 at 3:35 PM
I've used real skin shader with displacement in P6 and have had problems with the reflections.
SamTherapy ( ) posted Wed, 10 August 2005 at 3:43 PM
I have never been able to get displacement to render in P5 or P6.
maxxxmodelz ( ) posted Wed, 10 August 2005 at 7:19 PM · edited Wed, 10 August 2005 at 7:25 PM
"I don't have P5 here on my computer anymore and I found this one, I made series of the images with the same fur effect that reflect in the reflection, and used displacement maps..."
That image seems to confirm the same thing Stewer was saying, Cath. The "displacement" you see in the reflection looks more like a bump map, while the object itself is obviously real displacement. If you look closely at the edges of the object in the reflection, you'll see that they're still very smooth, while the displaced object above it has "furry", roughly displaced edges. It seems all P5 did there was turn your displacement map into a bump map in the reflection. It looks close, but not the same. :-) It's definitely not representing the displacement on the micro-polygon level in the reflection. Message edited on: 08/10/2005 19:25
byAnton ( ) posted Wed, 10 August 2005 at 8:41 PM
My understanding is that it is a known issue that was done to reduce raytracing render times. I don't want to speak for them but I have mentioned it to E-frontier and they already knew about it.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
maxxxmodelz ( ) posted Wed, 10 August 2005 at 11:59 PM
"My understanding is that it is a known issue that was done to reduce raytracing render times. I don't want to speak for them but I have mentioned it to E-frontier and they already knew about it." You mean it was deliberate "feature" they decided on? Hmmmm. Sounds like a lame excuse from E-frontier to me. ;-P If someone is using raytraced reflections with displacement, it seems logical that they would want the displacement reflected, regardless of rendertime impact. Otherwise, why bother using a reflective surface in the first place? Sounds more to me like a problem that they just haven't figured out yet. ;-) If it IS even technically possible to get micropolygon displacement visible in raytraced reflections, then why not the option of allowing us to turn it on or off? Maybe in a future update. ;-) Stewer, does micro-poly displacement show up in reflections with other hybrid REYES renderers? I don't know the answer, just curious if you do.
byAnton ( ) posted Thu, 11 August 2005 at 12:13 AM
I just know they know about it and it sounded like a render time concern atm. Don't get too outraged or anything. I don't want to get in trouble. Look at it like this. It might be easy to change in the future. :)
Mec4D ( ) posted Thu, 11 August 2005 at 12:30 AM
I render this one with Poser6, I used here displacement, I am not sure if the reflection was only Ambient occlusion in place of displacement it looks like....... anyway I hope it will be fixed soon... :)
maxxxmodelz ( ) posted Thu, 11 August 2005 at 2:04 AM
"Don't get too outraged or anything. I don't want to get in trouble." LOL. No worries, Anton. It takes a lot more than displacement and reflections to get me outraged. ;-P
mylemonblue ( ) posted Thu, 11 August 2005 at 4:39 AM
NaCl (Bookmark)
My brain is just a toy box filled with weird things
stewer ( ) posted Thu, 11 August 2005 at 6:20 AM
Well, some of them simply create a finer mesh and send that to the raytracer, the way non-micropolygon renderers like C4D do it, in which case you get all the disadvantages of that method (memory consumption, non-view dependent tessellation). SideFX' Mantra or Pixie require the user to define the tessellation level. Pixie's documentation notes that "True displacements for raytracing may be very expensive. "
The documentation of 3Delight 4.5 says the following:
"By default, 3Delight renders ray traced displaced geometry using bump mapping, meaning that only surface normals are affected by displacement shaders, not geometry.
OK, default is the same as FireFly's. Let's read on:
*it is important to note that there is an additional cost when using true geometric displacements in the context of ray tracing, for the following reasons:
3Delight needs more memory to hold displaced geometry (even though it uses a caching mechanism to reduce memory allocations).
Displacement bounds expand primitives' bounding boxes, this has a bad effect on ray tracer's space partitioner, meaning less efficient ray / primitive intersections. It is clear that badly set displacement bounds (or extreme displacement) can make ray tracing of true displacements very costly.
For many primitives, geometrical intersections are less efficient than the analytical algorithm 3Delight uses for non-displaced ray tracing."*
No information is given about the tessellation level or how to control it. And I can't experiment with it because 3Delight claims my license is expired and a new one refuses cooperation.
Pixar's PRMan - I have never used it and don't have it's manual, but judging by the papers the published, Pixar has put a lot of research work into raytracing large scenes, on-the-fly tessellation, multiresolution caching etc. Sounds like they have figured something out, and will probably sue your butt off if you implement the same ;)
BTW, Renderers like 3ds or C4d are not doing micropolygon displacement. For example, see this discussion:
http://forums.cgsociety.org/showthread.php?t=189573
an0malaus ( ) posted Fri, 12 August 2005 at 1:22 PM
Aha! That explains some of the effect I saw in P5 while rendering reflections of displacement maps. With improperly adjusted min displacement bounds, I would get vertex clipping artifacts in the direct view, but reflections appeared to show the displacement properly. I now realise I was seeing a bump map representation of the displacement in the reflections. Shining by reflected light ;-) Thanks for the detailed explanation Stefan :-)
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
Singular3D ( ) posted Fri, 12 August 2005 at 3:10 PM
Well, at least it's good to know. If you want to make a complex scene that relies on displacement reflection, it's good to know before you do it...
