Mon, Feb 10, 5:47 AM CST
Subject: Box Mode and invisible figure in Max 3 (pz3)
poserpro ( ) posted Thu, 22 February 2001 at 9:11 AM ยท edited Mon, 10 February 2025 at 5:42 AM
I opened a pz3 in Max 3 and the figure is a man with dress( hand band and footwear), when the file was loaded, I can't see the main figure, only the dress figures moving, and the figures are all in box after I hit animation button. any tips :) Also why there is alwasy a seam at the uvmap joints in LW when I load a p4 figure ?
dunga ( ) posted Thu, 22 February 2001 at 10:51 PM
when i click on the load pz3 scene only a box appears so I am bounded to use my own way of importing the animation and poser .PPP plugin becomes unusable...
poserpro ( ) posted Fri, 23 February 2001 at 12:06 AM
this happens in Max 4 to me, only a white bounding box appear:( And the usual way( not via ppp plugin), can be open in Max 4 and well textured ( the setup on Max 3)
dunga ( ) posted Fri, 23 February 2001 at 1:10 AM
max 4 does not support the ppp plugin!!!! this is something new...
poserpro ( ) posted Fri, 23 February 2001 at 1:55 AM
if you load a obj via duck's obj and save as *.max, in max 4, you can open the max. but if you open the paz3 and save as *.max, you can't open it in max 4.
