Your new version of Windows won't have the stuff that Poser puts in the registry when it's installed - I don't know what that is, but it sounds as if it's needed. You should be fine if you re-install Poser 5 over the top of the existing installation (i.e. on your old drive). If your content is all in the Poser 4 runtime, that will be safe. I don't think you'll need to re-install Poser 4 unless you still use it, and it gives trouble. Alternatively, you can do a fresh install of Poser 5 and point the new version to your old runtimes.
Hi all, I had a big crash on my PC and had to put in a new drive, the old drive I have made a slave the old drive has P4 and P5 on it, so I made a short cut to Poser 5 on the old Drive now when ever I go to load a figure or hair it cant find the OBJ, all my poser stuff is loaded in to poser 4 and I have add that Runtime to Poser 5, hope someone can help, thanks for your time and help..
Message edited on: 08/15/2005 22:55
