Fri, Jan 24, 1:30 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Subject: anyway to mirror morphs from one side of body to other
TRAVISB ( ) posted Sat, 24 February 2001 at 1:44 AM · edited Thu, 23 January 2025 at 11:20 PM
i use lw and carrara is this possible?
Jaager ( ) posted Sat, 24 February 2001 at 2:37 AM
PC or Mac? If PC, yes - MASA'a MTmirror.
TRAVISB ( ) posted Sat, 24 February 2001 at 2:50 AM
pc i tried it but i cant find a tut when i try to load the geom or obj files it wont let me sayinthat it isnt sym or exceeds lines
Jaager ( ) posted Sat, 24 February 2001 at 7:26 AM
1- You need a base for each group 2- You can not pull the X=0 verts out of line. This makes using it for magnet morphs tricky. The base groups are a single group if it is a central group = chest, neck, abdomen the pair if the group comes as a left and right pair. And only the group - no complexes rCollar&lCollar = yes rCollar&chest&lCollar = no The morph group must be the same complex as the base. It does not like Mike's chest or collars very much. It will swap, but not mirror. not a problem with collars, potential problem with chest
Bof1 ( ) posted Sat, 24 February 2001 at 1:56 PM
With LW 6 you can put symmetry to on
ronmolina ( ) posted Sun, 25 February 2001 at 9:12 AM
Bof is right and you can do full body morphs.I do it this way using the PPP and LightWave. Here is what I do: 1) I import from the Poser geom files the body obj I want to morph into Poser. 2) using the grouping tool I spawn props which gives me a prop for each body part. 3) I delete the original object and then export all the body parts as one mesh in LightWave format. Now I have a base figure and do not have to repeat steps 1 through 3 for that body type ever again. These three steps take less than two minutes. 4) I import into LightWave. 5) In LightWave I now have an object with all the material groups normally defined in Poser and a material for each body part. I can now pic a single body part to work on or multiple parts at the same time. 6) In Lightwave I set the mode to symmetry. Now for example I can pick the right forearm and anything I do to it also occurs on the left forearm I do my reshaping with a multitude of tools. I can also just pick a few points or polys on one side of the body and the change happens on the other side even with more than one body parts polys or points selected. 7) I pick the body parts I have morphed one by one from the Statistics window in LightWave and export them in object format. Now I have morphs that I just apply to each body part in Poser. Hope this helps. Ron
TRAVISB ( ) posted Sun, 25 February 2001 at 10:48 AM
Thank you very much ron 2 qustions do you import from the obj sile before (step one or just loadd from the character library? also do you have to select one body part at a time with the grouping tool? thanks pal
TRAVISB ( ) posted Sun, 25 February 2001 at 10:53 AM
ok i figured out the first two questions oh yeah did i say you KICK ASS
ronmolina ( ) posted Sun, 25 February 2001 at 10:55 AM
Glad you got it Trav any questions just ask will be gone from home for a few hours. Ron
TRAVISB ( ) posted Mon, 26 February 2001 at 10:54 AM
ok ive only had lw for a few days and just wanted to ask how do i decrease the load i have 400mhz ram and it isnt respondin almost at all how do i select body parts
TRAVISB ( ) posted Mon, 26 February 2001 at 11:39 AM
ok say i give vicki a big butt i go to statistics and choose l buttock_skin body it wont select only the cheek and when i export it doesnt work
ronmolina ( ) posted Mon, 26 February 2001 at 12:38 PM
Trav I know what the problem is and it is my fault. I did not tell you about these steps. Did these window shots for you. Seems you have it all right but the last part. Also when you get ready to export make sure you are no longer in symmetry mode. If you are in symmetry mode two opposing sides will be grouped. Follow these steps: 1)Seems you have fig1 and fig2 down. 2)Once you have selected your body part then click the + sign.Fig3 Now your body part should be highlighted. 3)then click at the bottom "copy." fig5 4)then go to a new layer and click paste. Your body part should now show up in the new layer. Fig4 and Fig5. 5) now export as obj. fig6 6) now click "cut" fig5 This will delete the body part in your second layer. 7) go back to your first layer where the full body is and repeat the process for each morph part. 8) add your morphed parts in Poser as normal. Let me know if this works for you. Ron
