Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
@Misha883:
OK, I've just read your tutorial which is there!.
What I have to say about it is:
But, anyway, thanks again!
I actually think both of them have a place. Perspctive give me the feeling of "wow so big and majestic" Straightedn one is a typical shot. Good in ways to just show off the building.But I have always liked perspective.
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
I would have thought the top image was just fine without having seen the second. There is my answer for ya! ;]
@hotracer2: sorry, I installed photFiltre in the froggies' language but here are the 5 steps of what I did:
-first, add an empty area on the side of the picture where you have to drag...
-Select the entire picture
-Click on the contextual menu (right click) on "transformation-->distorsion"
-Drag the upper left corner
-Clik on "valid"
And that's it!
@Nilla: you can find that stuff at photoFiltre.com.
Thanks a lot to all of you!
I was going to suggest Paint shop pro 8 and later but Cynlee beat me to it. 2# is the better version IMO but sometimes I feel that the distorted images work too.
I blame modern shoddy workmanship and refuse to correct their errors. Phidias in the 5th century BC was putting up buildings with the correct perspective when viewed from the ground. He curved the foundations so they looked correct when viewed. Of course he was building temples for the Gods. An example being the Parthenon in Athens.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
??? I don't get what you say... As far as I know, there isn't any acknowledge mechanism which informs RR ebots system that I read their message... Is it?? Anyway, I've just noticed the "Notify" checkbox, 6cm (2inches, gringos!!) below what I'm writing, right now... I gonna use it... Thanks, again, to all of you! Cheers!!...
