Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
I used Quick Conforme 1,1 for the CR2 doner CR2 was V3 blank..! I think Quick Conforme takes all actor/bone in the doner Cr2 so the hip should be covered :)
I don't know about Quick Conform, sorry... It might be worth checking for any translations in the hip or body part. Load your top by itself (don't conform) and if there are any non-zero translate dials in the hip or body, set them to 0.000. Then memorize the figure, and re-save back into the library.
Oki I found the problem Remember to zero the hip before doing any thing :) Thanks EnglishBob
I have this top for V3 I'm trying to make it to a conforming figure...Well it work fine only it jumps up under her head when I conform it so it must be the joint parameters that is wrong .!. Is ther any good tuts on how to set the joint parameters in a conforming figure ?
Rendergirls
