Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
I don't have Arduino's PG for Jessie and don't use her that much so I can't vouch for her vag open morph. I do have other Arduino PG's and can say that they kick butt and are easy to use. Can't help with the digistuff, but I'm sure others will sound off. I hope you don't plan on submitting the images here, it -might- be a violation of the TOS. lol You can submit them at RaunchyMinds (dotcom) though, I believe the gallery TOS there is a little more openminded regarding such matters. Unless, of course, you have your own personal gallery site where you intend to upload these... in which case you can PM me the URL. Thanks. ;)
Well I can recommend the PG's from Arduino for Jessi but they only work on HiRs Jessi not on Glam or Jessi standard. For James try Satanic Inc's Gens. They are designed for M3 and other MilFigures but work also on James. You only have to adjust it manually. Sorry, but I can't post an image here ;)
Ulli
Arduino's morphs on Jessi work fine, especially the version for Jessi "with genitals" (ahem). They work on Jessi Hires. The RDNA Jessi morph packs still work. And you could use the Sexy Slayer package, with Sexy Sidekick for Jessi (Wyrmmaster) to give her a little more versatility than the morphs allow.
AAAAAAAAAHHHHHHHHH someone said Genitals...... i fear i might now be stuck down by the powers that be... lol But i can say that i have PerfectG for V3,S3,Aiko3 and the GIRL, and they are all excellent. only quibble i have is they are made using the already existing meshes, and as such makes the genitals look a little "low Poly" at closer inspection, but that said you can't add more polygons to the V3 mesh and keep all those morphs so Arduino's PerfectG is Excellent and would suit your needs very well.
Getting old and still making "art" without soiling myself, now that's success.
All of the following are more than adequite. And they're all FREE: Hellborn's P3WWG Arduino's P4WWG v2 Latexa V2 NewEveV3 Eve 4
What they said. Arduino's stuff is excellent, particularly considering the relative lack of polygons in the nether regions of any of the meshes. Either Satanica's tool or the G4 for men is well worth the cost. The Digiport tongue takes a little work to get a good effect, but has far more flexibility that most of the tongues that come with the characters. Up until the G4 and Satanica genitals, all I used was the Digiport Digenitals. Not as versatile as the newest things, but still versatile in its own right.
If it's 'quim' that one's after, than the genitals on the P3WWG, P4WWG, Eve and Latexa are superior to the PG props. This is because thay're built into the mesh itself, and not added on as an extraneous prop. Add on props have a nasty habit of dropping off at extreme moments, rather disconceting to say the least. Also, as I said before... they're free!
I have decided to do some Hardcore renders using Jessie and James ( some monster are probably going to appear as well. The P6 character's OEM equipment is just not adequate for what I have in mind. So I have a simple question...
Is the Character and texture pac for jessie P6 adequate? I see it has a Vag open morph.
Is Arduino's Perfect G for jessie the best for this? I don't want to covert to V3 or another figure.
What about the digiport Tounge and digenitals figures from digiport?
Any advice is greatly appreciated, And since this is my first post here, I apologise in advance if this post is inappropriate.
